Going to do Architect install on the second ssd on new notebook, no dual boot
since I never made a manual install on efi system I was going to do it via architect using automated partitions and I’ve few question:
- will the automated install take care to set all the partitions needed?
- will the grub install be automated too?
- when it will come to video drivers install, selecting auto-install video drivers will use free or non-free? will Prime be used?
I’m thinking to use unconfigured desktop install too (plasma)
thanks
Yes, but I prefer to make a 100MB /boot/efi partition, and the rest for /
If you select grub, then yes, there are multiple options when it get to that step. I use rEFInd, but for a 1 distro setup, grub is fine.
Free or non-free depends on your video card. If you use NVIDIA, you want to use non-free.
sorry i made the wrong question…
I want to mean automatic partitioning…
And I said yes to your question:
system
Closed
5
