ExpressVPN daemon doesn't automatically start after boot
I successfully installed ExpressVPN. When I boot, I notice ExpressVPN isn’t starting because my internet connection is blocked. I run:
expressvpn connect
And get:
It seems that the expressvpn daemon is not running. Please run "sudo service expressvpn restart" to start it.
I then run:
And get:
sudo: service: command not found
This fixes it:
systemctl start expressvpn
ExpressVPN then starts working as normal. But I’d like to not have to run this command every time I boot. What can I do?
This is a fresh Manjaro install. ExpressVPN worked fine on a past Manjaro install, though I may have used a different installation method. Also currently works fine on Ubuntu.
Because thats incorrect.
Thats an ubuntu alias, not a real command.
It should be:
You can tell expressvpn that their client and instructions are faulty if you like :wink:
The same you would with any other service - enable it
systemctl enable expressvpn
(if you use the extra flag --now then it will also ‘start’ it)
