Hi, guys i am newbie to manjaro so please bear with me. After installing manjaro which by the way is only the one that i can successful install i faced several issues making this new installation working properly.Getting to the point i am issue with screen tearing event when scrolling webpage and battery drain issues. I don’t know how to get started so any help would be appreciated, Thank you.
Things i done so far
- I had issue with acpi_video while turning system on, So i edited some config in grub.
- I installed nvidia_amd_hybrid.450.xx-prime video drivers.
- Installed kernel 5.81-3 to fix speaker and mic problems and rebuild pulseaudio
- Installed optimus-manager and gdm-prime for optimus which leads me to battery drain issue
Now i don’t know which of the above process break it or screen tearing was there from beginning…so there’s that.
System: Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A Desktop: GNOME 3.36.5 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A serial:
Mobo: HP model: 8786 v: 22.53 serial: UEFI: AMI v: F.06 date: 07/15/2020
Battery: ID-1: BAT0 charge: 65.4 Wh condition: 70.2/70.2 Wh (100%) model: Hewlett-Packard Primary status: Discharging
CPU: Topology: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71880
Speed: 1397 MHz min/max: 1400/3000 MHz Core speeds (MHz): 1: 1397 2: 1398 3: 1397 4: 1396 5: 1397 6: 1393 7: 1397
8: 1393 9: 1397 10: 1397 11: 1397 12: 1397
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard driver: nvidia v: 450.57
bus ID: 01:00.0
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 06:00.0
Device-3: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 3-3:2
Display: x11 server: X.org 1.20.8 driver: ati,radeon unloaded: modesetting resolution:
OpenGL: renderer: GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.57 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel bus ID: 06:00.5
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 06:00.6
Sound Server: ALSA v: k5.8.1-3-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: e000 bus ID: 02:00.0
IF: eno1 state: down mac:
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0
IF: wlo1 state: up mac:
Drives: Local Storage: total: 476.94 GiB used: 247.29 GiB (51.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000H1 size: 476.94 GiB
Partition: ID-1: / size: 26.26 GiB used: 22.32 GiB (85.0%) fs: ext4 dev: /dev/nvme0n1p7
Swap: ID-1: swap-1 type: partition size: 2.00 GiB used: 241.1 MiB (11.8%) dev: /dev/nvme0n1p6
Sensors: System Temperatures: cpu: 42.8 C mobo: N/A
GPU: device: nvidia screen: :1.0 temp: 44 C device: amdgpu temp: 42 C
Info: Processes: 341 Uptime: 3h 45m Memory: 7.21 GiB used: 5.78 GiB (80.2%) Init: systemd Compilers: gcc: 10.1.0
Packages: 1225 Shell: Zsh v: 5.8 inxi: 3.1.05
