Screen start to flickering after update
After the last update my screen starts flickering, should I downgrade the driver?
mhwd -l -d --pci
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0166)
  Display controller Intel Corporation 3rd Gen Core processor Graphics Controller
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2024.05.06
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2024.05.06
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
Any suggestions?
Edit:
Something odd happens, if I raise the brightness to 100% the flickering stops
You cannot - i915 is provided with the kernel.
Perhaps using LTS kernel will provide a more stable driver.
Sorry, I’m not an experienced user.
I am using this kernel.
$ mhwd-kernel -li
Currently running: 6.5.13-7-MANJARO (linux65)
   * linux65
Which one should I use?
The kernel you are using has not been in Manjaro repos for many months.
sudo mhwd-kernel -i linux66 rmc
remember to
reboot
There is also a simple GUI to see all Kernels and you can add/remove one easily:
Taskbar>Settings>Manjaro Settings Manager>Kernel
