Screen sharing and screenshots only work with KDE/openbox, but not with KDE/X11 or KDE/Wayland. I had issues with screenshots for a long time, but I used them rarely, so I decided to live with that. But then I discovered, that screen sharing in zoom didn’t work either (from the app and from the browser). Tried with live-cd: Manjaro LXFCE, Ubuntu GNOME - everything works. Then I tried screen sharing with KDE/Wayland, KDE/openbox on the new user - KDE/Wayland can only share one window (when I share the whole screen, it’s just black with a cursor), and as it seems, KDE/openbox doesn’t have any issues at all. My main environment: KDE/X11 doesn’t work at all (even with one window): it doesn’t show the correct window, it lags, and constantly switches between two inactive windows. inxi -Fx
output:
Host: dan-lt Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81WE v: IdeaPad 3 15IIL05
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: EMCN47WW date: 07/29/2021
ID-1: BAT0 charge: 9.5 Wh (29.9%) condition: 31.8/35.0 Wh (90.9%)
volts: 7.9 min: 7.5 model: SMP L16M2PB2 status: Charging
Info: quad core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake rev: 5 cache: L1: 320 KiB L2: 2 MiB L3: 6 MiB
Speed (MHz): avg: 1100 high: 1102 min/max: 400/3600 cores: 1: 1100
2: 1101 3: 1100 4: 1100 5: 1101 6: 1102 7: 1101 8: 1100 bogomips: 19048
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:2
Display: x11 server: X.Org 1.21.1.2 driver: loaded: intel
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: e0:d4:64:08:b7:3b
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 117.98 GiB (24.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB temp: 33.9 C
ID-1: / size: 468.09 GiB used: 117.98 GiB (25.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 241 Uptime: 17m Memory: 7.33 GiB used: 2.04 GiB (27.8%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1541
Shell: Zsh v: 5.8 inxi: 3.3.11
