Hello, I'm using Manjaro GNOME in a VM and I wanted to change the screen resolution to 1080p. To achieve this I firstly used xrandr. Its a bit weird though, that the only output detected is "XWAYLAND0" and not "Virtual1". This is what I entered in the terminal:
~ $ cvt 1920 1080
# 1920x1080 59.96hz (CVT 2.07M9) hsync: 67.16 kHz; pclk: 173.00 MHz
Modeline "1920x1080_60.00" 173.00 1920 2048 2248 2567 1080 1083 1088 1120 -hsync +vsync
~ $ xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2567 1080 1083 1088 1120 -hsync +vsync
~ $ xrandr --addmode XWAYLAND0 1920x1080_60.00
But the screen resolution still does not show up in the display settings.
What I tried next was changing the GRUB screen resolution as shown in a YouTube tutorial.
I changed GRUB_GFXMODE
in my /etc/default/grub
to 1920x1080x32
and entered the command
~ $ sudo update-grub
But this also had no affect on my screen resolution.
How do I change my screen resolution?
