Screen Resolution is too low after auto adjust
[Solved] My monitor can’t seem to display the whole screen and only zooms in a portion of my screen and I can’t set it to work correctly, what to do now?
I solved by pressing auto adjust again after opening a maximized window, the screen resolution is back to normal.
Basically the auto adjust button on the monitor “sees” who big the window is and zooms in\out automatically.
