I’ve just updated and after that the Settings to switch the display doesn’t show the option for a “Single” display, but just “Join” or “Mirror”.
post formated output from:
inxi -Fazy
mhwd -l && mhwd -li
The output of inxi -Fazy
is:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=eee76dbb-5d66-47ee-9ccb-d8e69e394b0e rw quiet splash apparmor=1
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 20XWCTO1WW v: ThinkPad X1 Carbon Gen 9
Mobo: LENOVO model: 20XWCTO1WW serial: <superuser required> UEFI: LENOVO
v: N32ET75W (1.51 ) date: 12/02/2021
ID-1: BAT0 charge: 58.9 Wh (99.8%) condition: 59.0/57.0 Wh (103.4%)
volts: 17.5 min: 15.4 model: SMP 5B10W13973 type: Li-poly serial: <filter>
status: full cycles: 23
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2242 high: 3988 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1162 2: 944 3: 1646
4: 3988 5: 2833 6: 3186 7: 2074 8: 2110 bogomips: 44864
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel ports: active: HDMI-A-1 off: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-4:4 chip-ID: 04f2:b6ea class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) HDR 4K serial: <filter>
built: 2020 res: 3840x2160 dpi: 163 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: eDP-1 model: BOE Display 0x094c built: 2020 res: 1920x1200
dpi: 161 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 1920x1200
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: br-f373e8201b92 state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: veth049c9e9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth98da8a7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 158.03 GiB (33.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA512TFH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0002P7LN temp: 35.9 C scheme: GPT
ID-1: / raw-size: 150 GiB size: 146.59 GiB (97.72%) used: 45.26 GiB (30.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 326.64 GiB size: 320.45 GiB (98.10%)
used: 112.77 GiB (35.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ab481dd2-5357-4571-83e8-3bea7f66f3f2
System Temperatures: cpu: 62.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5976 fan-1: fan-2: 5976
Processes: 368 Uptime: 3h 34m wakeups: 17882 Memory: 15.35 GiB
used: 9.67 GiB (63.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1413 lib: 353 flatpak: 0
Shell: Zsh v: 5.8.1 running-in: guake inxi: 3.3.15
The output of mhwd -l && mhwd -li
is:
> 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
