So I just installed manjaro i3 and everything worked fine for a couple of reboots. I re-generated my locale to get the dmenu working.
i reboot for the 3rd time, the screen comes up and i can’t see anything. It looks all crazy. I am not sure if there’s a word for it but i am attaching a screenshot (captured from my phone) so you can look at it.
Note - It looks fine until the boot menu and then it starts showing up like this!
i dont know what it was. I kept my laptop shutdown for 5 minutes. restart it and its working as expected. Its been 4 hours now and no issues. I guess we can close this for now but that almost gave me a heart attack lol.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
P.P.S. Please also read the following article because IMGUR cannot be viewed if you turn your browser security settings to paranoid (No cookies / no scripts)
