Thank you. Here is the output:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3f112e64-17f5-473d-8e46-ad7c9c1669ff rw quiet splash
resume=UUID=873977d4-14a0-4b9b-bad7-ec23e01ef7e8 udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A wm: kwin_x11 with: krunner
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B650M MORTAR WIFI (MS-7D76) v: 2.0
serial: <filter> uuid: 196ba479-8a6e-2516-acb2-d843aeccbfc2 UEFI: American
Megatrends LLC. v: A.J1 date: 10/22/2024
Info: model: AMD Ryzen 5 7600X socket: AM5 bits: 64 type: MT MCP arch: Zen 4
gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB
desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2988 min/max: 545/5453 boost: enabled
base/boost: 4700/5450 scaling: driver: amd-pstate-epp governor: performance
volts: 1.3 V ext-clock: 100 MHz cores: 1: 2988 2: 2988 3: 2988 4: 2988
5: 2988 6: 2988 7: 2988 8: 2988 9: 2988 10: 2988 11: 2988 12: 2988
bogomips: 112852
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-3, DP-4, DP-5, HDMI-A-3, Writeback-2 bus-ID: 12:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 32.0 C
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) 27GN7
serial: <filter> built: 2022 res: mode: 1920x1080 hz: 240 scale: 100% (1)
dpi: 81 gamma: 1.2 size: 600x303mm (23.62x11.93") diag: 708mm (27.9")
ratio: 15:9, 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:747e
memory: 15.62 GiB unified: no
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640
class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: SteelSeries ApS Arctis Nova 7P
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 1038:220a class-ID: 0300
Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:7
chip-ID: 0db0:7696 class-ID: 0300
Device-6: XMOS JDS Labs Atom DAC+ driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 20b1:30e1
class-ID: fe01
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0e:00.0
IF: enp14s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:8 chip-ID: 0e8d:0616
Local Storage: total: 1.82 TiB used: 1001.06 GiB (53.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 34.9 C
scheme: GPT
SMART: yes health: PASSED on: 15d 12h cycles: 101
read-units: 4,163,317 [2.13 TB] written-units: 8,992,429 [4.60 TB]
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 1001.06 GiB (55.6%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: partition size: 33.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 38.0 C mobo: 30.2 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 37.0 C mem: 32.0 C fan: 0 watts: 10.00
device: amdgpu temp: 32.0 C
Packages: pm: pacman pkgs: 1469 libs: 441 tools: pamac
1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
3: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
4: https://manjaro.kurdy.org/stable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
8: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
9: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
10: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
11: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
12: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
13: https://mirror.easyname.at/manjaro/stable/$repo/$arch
14: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
15: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
16: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
17: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
18: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
19: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
20: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
21: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
22: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
23: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
24: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
25: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
26: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
28: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
29: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
30: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
31: https://linorg.usp.br/manjaro/stable/$repo/$arch
32: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
33: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
35: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
36: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
37: https://mirrors.manjaro.org/repo/stable/$repo/$arch
38: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
39: https://mirror.init7.net/manjaro/stable/$repo/$arch
40: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
41: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
42: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
43: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
44: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
46: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
47: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
48: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
49: https://mirror.funami.tech/manjaro/stable/$repo/$arch
50: https://manjaro.ynh.ovh/stable/$repo/$arch
51: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
52: http://mirror.fcix.net/manjaro/stable/$repo/$arch
53: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
54: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
55: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
56: https://mirror.koddos.net/manjaro/stable/$repo/$arch
57: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
58: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://mirrors2.manjaro.org/stable/$repo/$arch
60: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
61: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
62: https://mirror.zetup.net/manjaro/stable/$repo/$arch
63: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
64: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
65: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
66: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
67: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
70: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
71: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
72: https://mirror.dc.uz/manjaro/stable/$repo/$arch
73: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
74: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
75: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
76: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
77: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
78: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
79: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
80: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
81: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
82: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
83: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
84: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
85: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
86: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
88: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
90: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
91: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
92: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
94: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
95: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
96: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
97: https://muug.ca/mirror/manjaro/stable/$repo/$arch
98: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
99: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
100: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
101: https://mirror.23m.com/manjaro/stable/$repo/$arch
102: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
103: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
104: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
105: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
106: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
107: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
108: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
109: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
110: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
111: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
112: http://manjaro.grena.ge/stable/$repo/$arch
113: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
114: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
115: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
116: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
117: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
118: http://manjaro.mirror.ac.za/stable/$repo/$arch
119: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
Memory: total: 32 GiB note: est. available: 30.46 GiB used: 3.44 GiB (11.3%)
Processes: 343 Power: uptime: 6h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.16 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
