Hey guys, everything is working fine, even volume slider, but when I press Fn + Left or Right to change brightness, screen freezes for 1 or 2 seconds, then it works as it should, it freezes to make the volume slider appear, I need help fixing it…
Welcome to Manjaro!
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=9cb6a6d4-92dc-491a-93b1-873211f1b763 rw udev.log_priority=3
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire E5-471 v: V3.72 serial: <filter>
Mobo: Acer model: EA40_HB v: Type2 - A01 Board Version serial: <filter>
UEFI [Legacy]: Insyde v: 1.25 date: 01/15/2015
ID-1: BAT1 charge: 43.8 Wh condition: 45.1/55.9 Wh (81%) volts: 12.6/11.1
model: SANYO AL14A32 type: Li-ion serial: <filter> status: Discharging
RAM: total: 3.77 GiB used: 1.27 GiB (33.7%)
RAM Report:
Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F
L2 cache: 3072 KiB bogomips: 15971
Speed: 799 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 912 2: 1080
3: 1348 4: 1059
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1616
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 2-7:3
chip ID: 04f2:b469
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:160c
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:9ca0
Sound Server: ALSA v: k5.8.3-2-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
chip ID: 168c:0036
Local Storage: total: 931.51 GiB used: 12.39 GiB (1.3%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: 1.00
dev-links: cdrom
ID-1: / raw size: 200.00 GiB size: 195.86 GiB (97.93%)
used: 8.95 GiB (4.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 9cb6a6d4-92dc-491a-93b1-873211f1b763
ID-2: /home raw size: 725.51 GiB size: 713.12 GiB (98.29%)
used: 3.44 GiB (0.5%) fs: ext4 dev: /dev/sda3 label: N/A
uuid: cad7ebd2-28c0-4774-9010-2964254b440a
ID-1: /dev/sda1 size: 6.00 GiB fs: swap label: N/A
uuid: e460ba84-f8b7-4600-bf01-dbaa80ccd5ec
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8001
Hub: 2-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
Device-1: 2-7:3 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b469
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 226 Uptime: 8m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1055 lib: 292 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
You have an Intel driver which I’m not very familiar with (I’m on pure nVidia)
but for the next person that comes around please prepare the output to:
mhwd --listinstalled
(I’ve also edited your title to attract more knowledgeable people than me)
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
