Screen flickers when use Manjaro bootable pendrive MSI
  Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_GNOMEM_2131 quiet
    systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
    radeon.modeset=1
  Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: Micro-Star product: Sword 15 A12UE v: REV:1.0
  Mobo: Micro-Star model: MS-1583 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E1583IMS.106 date: 01/18/2022
  ID-1: BAT1 charge: 50.0 Wh (99.0%) condition: 50.5/52.0 Wh (97.1%)
    volts: 13.0 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: charging
  RAM: total: 15.34 GiB used: 2.01 GiB (13.1%)
  RAM Report:
  Info: model: 12th Gen Intel Core i7-12650H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
    family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
  Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
    L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 433 high: 481 min/max: 400/4679:4700:3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 470 2: 466 3: 420 4: 427
    5: 423 6: 424 7: 481 8: 427 9: 478 10: 420 11: 469 12: 432 13: 400 14: 400
    15: 400 16: 400 bogomips: 86048
    arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
    cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
    cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
    umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a3
    class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520
    class-ID: 0300
  Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-6:3
    chip-ID: 5986:211b class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0xaf90 built: 2020 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.2
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:228e class-ID: 0403
  Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: no
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
    bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 961.37 GiB used: 0 KiB (0.0%)
    model: PC SN540 SDDPNPF-1T00-1032 size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 33006000 temp: 24.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: Flash Disk
    size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
    serial: <filter> rev: 8.07 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: SYSTEM
    uuid: 7C46-C869
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 490.69 GiB fs: ntfs
    label: Windows uuid: D260473760472219
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 900 MiB fs: ntfs
    label: WinRE tools uuid: 3E4247CE4247899B
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 22.43 GiB fs: ntfs
    label: BIOS_RVY uuid: CAA849ADA8499939
  ID-6: /dev/sda1 maj-min: 8:1 size: 2.56 GiB fs: iso9660
  ID-7: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 43CB-F1AC
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-5:2 info: Alcor Micro Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
    chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
  Device-2: 1-6:3 info: Acer HD Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211b
    class-ID: 0e02
  Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 54.0 C mobo: N/A
  Processes: 342 Uptime: 2m wakeups: 570 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
  Packages: pacman: 939 lib: 272 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.19
Secure boot is off. After the GUI for any desktop loads (KDE/Gnome), as soon as I move the mouse the screen starts flickering and then blacks out. It remains fine if I do not move the mouse and even when I type. I don’t think its a Manjaro problem though that’s just a guess. This remains when I use the propriety drivers.
Also note that this is happening when I’m trying to install Manjaro on my new system (along with Windows).
