Hi,
When I edit the display resolution, the SDDM is not respecting it and still very small.
I tried (SDDM apply plasma settings), but it didn’t work.
I also tried (Enable HiDPI), but nothing happened.
Furthermore, I actually had the same issue when I was using vanilla arch and I fixed it, but I don’t remember the solution.
Instead of using the distribution file - you should create your own as described in man ssdm.conf
DisplayCommand=
Path of script to execute when starting the display server. The script will be executed as root when General.DisplayServer is “x11”, otherwise as sddm user. Default value is “/usr/share/sddm/scripts/Xsetup”.
The configuration is similar for Wayland
Place a dropin file in /etc/sddm.conf.d with your script
