Hello and thank you for viewing this topic. I’ve used manjaro for long time with kde and ext4. This time i decided to install xfce with btrfs. There was no problem with the previous setup so the issue might be with xfce or btrfs i dont know. My laptop’s screen is flickering when screen locked due to waiting and when i connected hdmi and change settings 1 or 2 times its flickering again. I’ve recorded a video so you can see it. Can you help me ?
This is video link: https://www.youtube.com/watch?v=SgMjukupB2I
This is my system:
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=436959fa-a75e-44ea-b966-57b3d45bf337 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=26c9eecb-d14a-4bf9-8852-9f3bbd5d838e udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81N3 v: Lenovo IdeaPad S145-15AST
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S145-15AST
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679WIN serial: <filter>
UEFI: LENOVO v: AYCN21WW date: 12/27/2019
ID-1: BAT0 charge: 21.8 Wh (94.8%) condition: 23.0/30.0 Wh (76.6%)
volts: 8.4 min: 7.6 model: SMP L17M2PB7 type: Li-poly serial: <filter>
status: Unknown
Info: Dual Core model: AMD A9-9425 RADEON R5 5 COMPUTE CORES 2C+3G
bits: 64 type: MCP arch: Excavator family: 15 (21) model-id: 70 (112)
stepping: 0 microcode: 6006705 cache: L2: 1024 KiB
bogomips: 12383
Speed: 1552 MHz min/max: 1400/3100 MHz boost: enabled Core speeds (MHz):
1: 1552 2: 1446
disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-1.3:4 chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1818 s-dpi: 96 s-size: 445x481mm (17.5x18.9")
s-diag: 655mm (25.8")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 90
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: AMD STONEY (DRM 3.41.0 5.13.12-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.2.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-2:2 chip-ID: 08bb:2902
class-ID: 0300
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 1000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.2:3 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 17.89 GiB (7.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS256G32TNH-73A0A
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0Q00 scheme: GPT
ID-1: / raw-size: 85.97 GiB size: 85.97 GiB (100.00%)
used: 17.86 GiB (20.8%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 85.97 GiB size: 85.97 GiB (100.00%)
ID-4: /var/log raw-size: 85.97 GiB size: 85.97 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 768 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 63.5 C mobo: N/A
GPU: device: amdgpu temp: 53.0 C device: amdgpu temp: 63.0 C
Processes: 206 Uptime: 14m wakeups: 1 Memory: 3.23 GiB
used: 2.36 GiB (72.8%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1141 lib: 311 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
