I have tried several versions of Manjaro. KDE, Gnome, Cinammon. They all have the same screen flickering issue. I have tried a few solutions, but none have worked so far.
This is the output from inxi:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=27d69fc7-f777-4f39-8b56-33212ec54947 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Aspire E5-553 v: V1.31
serial: <superuser required>
Mobo: Acer model: Wasp_BR v: V1.31 serial: <superuser required>
UEFI-[Legacy]: Insyde v: 1.31 date: 03/28/2018
ID-1: BAT1 charge: 9.6 Wh (100.0%) condition: 9.6/41.4 Wh (23.2%)
volts: 16.4 min: 14.8 model: PANASONIC AS16A5K type: Li-ion
serial: <filter> status: full
Info: model: AMD A12-9700P RADEON R7 10 COMPUTE CORES 4C+6G bits: 64
type: MT MCP arch: Excavator built: 2015 process: GF 28nm family: 0x15 (21)
model-id: 0x65 (101) stepping: 1 microcode: 0x600611A
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB desc: d-4x32
KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1483 high: 2060 min/max: 1300/2500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1293 2: 2060
3: 1296 4: 1285 bogomips: 19970
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Acer Incorporated ALI
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
Device-2: Realtek HD WebCam type: USB driver: uvcvideo bus-ID: 2-1:2
chip-ID: 0bda:57f3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x70ec built: 2015
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: AMD CARRIZO (LLVM 14.0.6 DRM 3.42 5.15.60-1-MANJARO)
v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer
Incorporated ALI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb v: 0.8 bus-ID: 1-1.3:4 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 931.51 GiB used: 22.22 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3J scheme: MBR
ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 22.22 GiB
(2.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 51.8 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 214 Uptime: 14m wakeups: 1 Memory: 15.09 GiB used: 2.12 GiB
(14.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1225 lib: 322
flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
I have tried the solution of changing the X11 configuration by modifying:
- /etc/X11/xorg.conf.d/20-amdgpu.conf*
and changing it to:
ection "Device"
Identifier "AMD"
Driver "amdgpu"
Option "TearFree" "true"
Option "AccelMethod" "uxa"
EndSection
As suggested on other threads.
But the issue still persists. Checking on the Arch Linux forums, some have suggested downgrading the Kernel version. But not sure if that would help.
For the record, I come from Debian Bullseye, where the issue is not present.
Let me know if there’s anything else I could try.
