Since the last xorg/wayland update (or very recently):
[2021-04-19T17:19:10-0400] [ALPM] upgraded xorg-xwayland (21.1.0-1 -> 21.1.1-1)
I’m getting memory corruptions in the display/picture.
Not big blocks, but many short horizontal lines, flicker all over the display, every few seconds.
Laptop, Lenovo 14. XFCE desktop.
A dragged window is really bad, almost 50% corruption.
My first thought - how can I downgrade to a previous version?
ie. what total list of packages should I downgrade?
Second - here is my info, if anyone wants to know and ask questions:
# inxi -Fazy
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=f1ce2124-63bd-49bc-ac87-5b1e887649c9 rw udev.log_priority=3
Console: tty pts/0 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20SL v: Lenovo ThinkBook 14-IIL
serial: <filter> Chassis: type: 10 v: Lenovo ThinkBook 14-IIL
serial: <filter>
Mobo: LENOVO model: LVAC/LVAD v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: DJCN17WW date: 04/15/2020
ID-1: BAT1 charge: 42.0 Wh (95.7%) condition: 43.9/45.0 Wh (97.5%)
volts: 12.7 min: 11.4 model: SMP L19M3PF1 type: Li-poly serial: <filter>
status: Unknown cycles: 53
Info: Quad Core model: Intel Core i7-1065G7 socket: U3E1 bits: 64
type: MT MCP arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5
microcode: A0 cache: L2: 8 MiB
bogomips: 23961
Speed: 865 MHz min/max: 400/3900 MHz base/boost: 1300/1500 volts: 0.7 V
ext-clock: 100 MHz Core speeds (MHz): 1: 865 2: 1265 3: 1262 4: 1257 5: 1188
6: 1265 7: 1264 8: 1255
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:5
chip-ID: 5986:2130 class-ID: 0e02
Display: server: X.org 1.20.11 compositor: compiz v: 0.9.14.1 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa tty: 80x24
Message: Advanced graphics data unavailable in console for root.
Device-1: Intel Smart Sound Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:34c8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
driver: iwlwifi v: kernel port: 3000 bus-ID: 00:14.3 chip-ID: 8086:34f0
class-ID: 0280
IF: wifi0 state: up mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0
IF: net0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:7 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 296.03 GiB (31.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 1B2QEXP7 temp: 33.9 C
scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.97 GiB (97.93%) used: 36.86 GiB (75.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 280 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 230 Uptime: 3h 59m wakeups: 1 Memory: 15.16 GiB
used: 3.24 GiB (21.4%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1453 lib: 431 flatpak: 0 Shell: Bash (su)
v: 5.1.4 running-in: tty pts/0 inxi: 3.3.04
Thanks,
John.
