So today I put my laptop into sleep, then it woke up, I snapped a screenshot quickly.
I have Nvidia proprietary drivers installed by default and 5.17 kernel.
Also, this is a laptop
Any idea?
provide formated output of:
inxi --admin --verbosity=7 --filter --width
mhwd -li
is this a fresh install?
if no, did it started to happen after the recent update?
try switching kernels to 5.15 and 5.10 and try with them
It is a fresh install, here is the output:
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=2b85619c-6ca4-4e09-b973-bb1a176d3f45 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=21a3a213-4da9-44f1-b436-c68285faeb1b udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G531GU_G531GU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G531GU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G531GU.311 date: 02/19/2021
ID-1: BAT0 charge: 29.4 Wh (60.2%) condition: 48.8/66.0 Wh (73.9%)
volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging
RAM: total: 15.48 GiB used: 5.16 GiB (33.3%)
RAM Report:
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2506 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 2600 2: 2430 3: 2600
4: 2600 5: 2540 6: 2600 7: 2600 8: 2600 9: 2600 10: 2466 11: 1837 12: 2600
bogomips: 62431
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2191
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia gpu: i915,nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,right
model: Samsung LC24RG50 serial: <filter> built: 2021 res: 1920x1080 dpi: 92
gamma: 1.2 size: 532x304mm (20.94x11.97") diag: 613mm (24.1") ratio: 16:9
modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: primary,left
model: Najing CEC Panda 0x0036 built: 2018 res: 1920x1080 hz: 120 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.49 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 893.87 GiB (63.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
used: 91.89 GiB (19.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 2b85619c-6ca4-4e09-b973-bb1a176d3f45
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9D3A-9906
ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-4: /home/<filter>/HDD raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 801.97 GiB (87.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: b5771feb-ddeb-4e65-a6f0-ce064735e8ef
ID-5: /run/timeshift/backup raw-size: 467.84 GiB
size: 467.84 GiB (100.00%) used: 91.89 GiB (19.6%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
ID-6: /var/cache raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-7: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 2 MiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 21a3a213-4da9-44f1-b436-c68285faeb1b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-2:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.2:4 info: Razer USA DeathAdder Essential
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:006e class-ID: 0300
Device-2: 1-2.4:6 info: China Resource Semico USB Keyboard type: Keyboard
power: 100mA chip-ID: 1a2c:4bbc class-ID: 0301
Device-3: 1-8:3 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:1866 class-ID: 0301
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 66.0 C pch: 56.0 C mobo: N/A gpu: nvidia
temp: 70 C
Fan Speeds (RPM): cpu: 4500
Processes: 379 Uptime: 34m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1769 pacman: 1762 lib: 466
flatpak: 7 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
and did you try switching kernels to 5.15 and 5.10 and try with them
Okay I will
