A screeching static sound is playing through my TV when I open an application for about 2 seconds. I also hear it when I start to play any kind of audio such as spotify, youtube, clementine etc. My computer is connected to a TV through HDMI cable.
Update 9/12/22: I upgraded the new stable manjaro release which updated Pipewire to 0.3.57 but this didn’t fix the issue.
Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=b916fe20-71bb-4c35-b117-9148dc097e93 rw quiet apparmor=1
security=apparmor resume=UUID=939a4204-b488-49c3-952a-2345f8e444de
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C02 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.E0
date: 06/09/2020
Device-1: hidpp_battery_0 model: Logitech M310 serial: <filter> charge: 55%
(should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2459 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2514
3: 2200 4: 2200 5: 3594 6: 2200 7: 3600 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 86424
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 26:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung built: 2012
res: 1920x1080 hz: 60 dpi: 43 gamma: 1.2 size: 1124x627mm (44.25x24.69")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 14.0.6 DRM 3.47
5.19.1-3-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 26:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 931.51 GiB used: 269.5 GiB (28.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 type: SSD serial: <filter> rev: RKT30Q.1 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 914.08 GiB size: 898.66 GiB (98.31%) used: 269.5 GiB
(30.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 60.5 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 836
Processes: 321 Uptime: 2h 14m wakeups: 6 Memory: 15.57 GiB used: 3.39 GiB
(21.8%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: 1481 pm: pacman pkgs: 1464 libs: 402
tools: pamac,yay pm: flatpak pkgs: 17 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
