I have installed Manjaro on my Convertible Thinkpad (X1 Yoga). The pen works great out of the box except if i use it in Dolphin.
The problem is that the pen input is registered about 5mm below where my pen tip actually is. So for example if i click on a certain file it actually selects the file below.
I have not found any solution, not even someone having the same problem.
I know that the Manjaro community is very helpful and now i hope someone here can help me with this problem
I did not install xf86-input-wacom because i already have xf86-input-libinput and i think they would interfere with each other. Apart from Dolphin my pen works fine.
If you still think i should install xf86-input-wacom, should i first uninstall xf86-input-libinput? And is there anything else i should watch out for?
