Wine not able to find the vulkan
When I try to run a game using vulkan in wine.
It gives me
Requested buffer size 32768, fragment size 8192
ALSA pcm 'default' set buffer size 32768, period size 8192 bytes
TiMidity starting in ALSA server mode
Opening sequencer port: 128:0 128:1 128:2 128:3
007c:fixme:hid:handle_IRP_MN_QUERY_ID Unhandled type 00000005
0024:fixme:exec:SHELL_execute flags ignored: 0x00004000
010c:fixme:win:RegisterTouchWindow (0000000000010064 00000003): stub
0098:fixme:imm:ImeSetActiveContext (0000000000010026, 0): stub
0098:fixme:imm:ImmReleaseContext (0000000000010020, 0000000000010026): stub
010c:fixme:imm:ImmReleaseContext (0000000000010064, 000000000002004C): stub
010c:fixme:msctf:ThreadMgr_ActivateEx Unimplemented flags 0x4
010c:fixme:imm:ImeSetCompositionString PROBLEM: This only sets the wine level string
010c:fixme:imm:ImeSetCompositionString Reading string unimplemented
010c:fixme:imm:NotifyIME NI_CLOSECANDIDATE
010c:fixme:imm:ImeSetActiveContext (000000000002004C, 1): stub
010c:err:vulkan:init_vulkan Failed to load Wine graphics driver supporting Vulkan.
010c:fixme:win:RegisterTouchWindow (0000000000030064 00000003): stub
010c:fixme:wgl:X11DRV_wglChoosePixelFormatARB unused pfAttribFList
010c:fixme:wgl:ConvertAttribWGLtoGLX unsupported 201e WGL Attribute
010c:fixme:wgl:ConvertAttribWGLtoGLX unsupported 201f WGL Attribute
010c:fixme:wgl:ConvertAttribWGLtoGLX unsupported 2020 WGL Attribute
010c:fixme:wgl:ConvertAttribWGLtoGLX unsupported 2021 WGL Attribute
010c:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
I have also installed dxvk through winetricks.
My installed vulkan packages are
$ pacman -Qs vulkan
local/amd-vulkan-prefixes 1-1
    Select needed vulkan implementation with vk_radv, vk_amdvlk or vk_pro prefix
local/amdvlk 2022.Q4.4-3
    AMD's standalone Vulkan driver
local/lib32-amdvlk 2022.Q4.4-3
local/lib32-vulkan-icd-loader 1.3.240-1
    Vulkan Installable Client Driver (ICD) Loader (32-bit)
local/lib32-vulkan-radeon 22.3.5-1
    Radeon's Vulkan mesa driver (32-bit)
local/spirv-tools 2022.1-1 (vulkan-devel)
    API and commands for processing SPIR-V modules
local/vkquake2-git r873.89eee38-1
    id Software's Quake 2 v3.21 with Vulkan support
local/vulkan-headers 1:1.3.240-1 (vulkan-devel)
    Vulkan header files
local/vulkan-icd-loader 1.3.240-1
local/vulkan-mesa-layers 22.3.5-1
    Mesa's Vulkan layers
local/vulkan-radeon 22.3.5-1
local/vulkan-tools 1.3.240-1 (vulkan-devel)
    Vulkan Utilities and Tools
My vulkaninfo is
VULKANINFO
Vulkan Instance Version: 1.3.239
Instance Extensions: count = 18
	VK_EXT_acquire_drm_display             : extension revision 1
	VK_EXT_debug_report                    : extension revision 10
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_portability_enumeration         : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
Layers: count = 9
VK_LAYER_AMD_switchable_graphics_32 (AMD switchable graphics layer) Vulkan version 1.3.235, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 1
		GPU id = 0 (AMD Radeon Vega 8 Graphics)
		Layer-Device Extensions: count = 0
VK_LAYER_AMD_switchable_graphics_64 (AMD switchable graphics layer) Vulkan version 1.3.235, layer version 1:
	Devices: count = 1
VK_LAYER_INTEL_nullhw (INTEL NULL HW) Vulkan version 1.1.73, layer version 1:
	Devices: count = 1
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.3.211, layer version 1:
	Devices: count = 1
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.3.211, layer version 1:
	Devices: count = 1
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
	Devices: count = 1
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
	Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
	Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
	Devices: count = 1
Presentable Surfaces:
GPU id : 0 (AMD Radeon Vega 8 Graphics):
	Surface type = VK_KHR_xcb_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_UNORM
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_SRGB
	Present Modes: count = 3
		PRESENT_MODE_IMMEDIATE_KHR
		PRESENT_MODE_MAILBOX_KHR
		PRESENT_MODE_FIFO_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount = 2
		maxImageCount = 16
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 2
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
			COMPOSITE_ALPHA_INHERIT_BIT_KHR
		supportedUsageFlags: count = 6
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters:
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			AMD Radeon Vega 8 Graphics (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		AMD Radeon Vega 8 Graphics (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion        = 1.3.235 (4206827)
	driverVersion     = 2.0.249 (8388857)
	vendorID          = 0x1002
	deviceID          = 0x15d8
	deviceType        = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
	deviceName        = AMD Radeon Vega 8 Graphics
	pipelineCacheUUID = 13eed3aa-5dd3-5239-93fb-bafc507fc5c2
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 16384
	maxImageDimension2D                             = 16384
	maxImageDimension3D                             = 2048
	maxImageDimensionCube                           = 16384
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 4294967295
	maxUniformBufferRange                           = 4294967295
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 128
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 1048576
	bufferImageGranularity                          = 0x00000001
	sparseAddressSpaceSize                          = 0x7ffd00000000
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 4294967295
	maxPerStageDescriptorUniformBuffers             = 4294967295
	maxPerStageDescriptorStorageBuffers             = 4294967295
	maxPerStageDescriptorSampledImages              = 4294967295
	maxPerStageDescriptorStorageImages              = 4294967295
	maxPerStageDescriptorInputAttachments           = 4294967295
	maxPerStageResources                            = 4294967295
	maxDescriptorSetSamplers                        = 4294967295
	maxDescriptorSetUniformBuffers                  = 4294967295
	maxDescriptorSetUniformBuffersDynamic           = 8
	maxDescriptorSetStorageBuffers                  = 4294967295
	maxDescriptorSetStorageBuffersDynamic           = 8
	maxDescriptorSetSampledImages                   = 4294967295
	maxDescriptorSetStorageImages                   = 4294967295
	maxDescriptorSetInputAttachments                = 4294967295
	maxVertexInputAttributes                        = 64
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 4294967295
	maxVertexInputBindingStride                     = 16383
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4096
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 127
	maxGeometryInputComponents                      = 128
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 1023
	maxGeometryTotalOutputComponents                = 4095
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 4294967295
	maxComputeSharedMemorySize                      = 65536
	maxComputeWorkGroupCount: count = 3
		65535
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		1024
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 15.9961
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		16384
		16384
	viewportBoundsRange: count = 2
		-32768
		32767
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 64
	minTexelBufferOffsetAlignment                   = 0x00000004
	minUniformBufferOffsetAlignment                 = 0x00000010
	minStorageBufferOffsetAlignment                 = 0x00000004
	minTexelOffset                                  = -64
	maxTexelOffset                                  = 63
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -2
	maxInterpolationOffset                          = 1
	subPixelInterpolationOffsetBits                 = 8
	maxFramebufferWidth                             = 16384
	maxFramebufferHeight                            = 16384
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferNoAttachmentsSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 40
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		0
		8191.88
	lineWidthRange: count = 2
		0
		8191.88
	pointSizeGranularity                            = 0.125
	lineWidthGranularity                            = 0.125
	strictLines                                     = false
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000001
	optimalBufferCopyRowPitchAlignment              = 0x00000001
	nonCoherentAtomSize                             = 0x00000080
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = true
	residencyStandard2DMultisampleBlockShape = false
	residencyStandard3DBlockShape            = true
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0
	maxExtraPrimitiveOverestimationSize         = 0
	extraPrimitiveOverestimationSizeGranularity = 0
	primitiveUnderestimation                    = true
	conservativePointAndLineRasterization       = false
	degenerateTrianglesRasterized               = true
	degenerateLinesRasterized                   = false
	fullyCoveredFragmentShaderInputVariable     = false
	conservativeRasterizationPostDepthCoverage  = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 3
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 4294967295
	shaderUniformBufferArrayNonUniformIndexingNative     = false
	shaderSampledImageArrayNonUniformIndexingNative      = false
	shaderStorageBufferArrayNonUniformIndexingNative     = false
	shaderStorageImageArrayNonUniformIndexingNative      = false
	shaderInputAttachmentArrayNonUniformIndexingNative   = false
	robustBufferAccessUpdateAfterBind                    = false
	quadDivergentImplicitLod                             = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 4294967295
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 4294967295
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 4294967295
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 4294967295
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 4294967295
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 4294967295
	maxPerStageUpdateAfterBindResources                  = 4294967295
	maxDescriptorSetUpdateAfterBindSamplers              = 4294967295
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 4294967295
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 4294967295
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindSampledImages         = 4294967295
	maxDescriptorSetUpdateAfterBindStorageImages         = 4294967295
	maxDescriptorSetUpdateAfterBindInputAttachments      = 4294967295
VkPhysicalDeviceDriverProperties:
	driverID        = DRIVER_ID_AMD_OPEN_SOURCE
	driverName      = AMD open-source driver
	driverInfo      = 2022.Q4.4 (LLPC)
	conformanceVersion:
		major    = 1
		minor    = 3
		subminor = 0
		patch    = 0
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = true
	shaderDenormPreserveFloat64           = true
	shaderDenormFlushToZeroFloat16        = true
	shaderDenormFlushToZeroFloat32        = true
	shaderDenormFlushToZeroFloat64        = true
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = true
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 00000000-0700-0000-0000-000000000000
	driverUUID      = 414d442d-4c49-4e55-582d-445256000000
	deviceNodeMask  = 1
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockProperties:
	maxInlineUniformBlockSize                               = 65536
	maxPerStageDescriptorInlineUniformBlocks                = 16
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 16
	maxDescriptorSetInlineUniformBlocks                     = 16
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 16
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 4294967295
	maxMemoryAllocationSize = 0x80000000
VkPhysicalDeviceMaintenance4Properties:
	maxBufferSize = 0x80000000
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 6
	maxMultiviewInstanceIndex = 4294967295
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 7
	pciDevice   = 0
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
	provokingVertexModePerPipeline                       = true
	transformFeedbackPreservesTriangleFanProvokingVertex = true
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000004
	robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 3
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleLocationGridSize:
		width  = 2
		height = 2
	sampleLocationCoordinateRange: count = 2
		0
		1
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceShaderIntegerDotProductProperties:
	integerDotProduct8BitUnsignedAccelerated                                      = false
	integerDotProduct8BitSignedAccelerated                                        = false
	integerDotProduct8BitMixedSignednessAccelerated                               = false
	integerDotProduct4x8BitPackedUnsignedAccelerated                              = false
	integerDotProduct4x8BitPackedSignedAccelerated                                = false
	integerDotProduct4x8BitPackedMixedSignednessAccelerated                       = false
	integerDotProduct16BitUnsignedAccelerated                                     = true
	integerDotProduct16BitSignedAccelerated                                       = true
	integerDotProduct16BitMixedSignednessAccelerated                              = false
	integerDotProduct32BitUnsignedAccelerated                                     = false
	integerDotProduct32BitSignedAccelerated                                       = false
	integerDotProduct32BitMixedSignednessAccelerated                              = false
	integerDotProduct64BitUnsignedAccelerated                                     = false
	integerDotProduct64BitSignedAccelerated                                       = false
	integerDotProduct64BitMixedSignednessAccelerated                              = false
	integerDotProductAccumulatingSaturating8BitUnsignedAccelerated                = false
	integerDotProductAccumulatingSaturating8BitSignedAccelerated                  = false
	integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated         = false
	integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated        = false
	integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated          = false
	integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
	integerDotProductAccumulatingSaturating16BitUnsignedAccelerated               = true
	integerDotProductAccumulatingSaturating16BitSignedAccelerated                 = true
	integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating32BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating32BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating64BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating64BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated        = false
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 64
	supportedStages: count = 6
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
	supportedOperations: count = 8
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlProperties:
	minSubgroupSize              = 64
	maxSubgroupSize              = 64
	maxComputeWorkgroupSubgroups = 4294967295
	requiredSubgroupSizeStages: count = 1
VkPhysicalDeviceTexelBufferAlignmentProperties:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000004
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000004
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 4294967295
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffff
	maxTransformFeedbackStreamDataSize         = 512
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 512
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = true
	transformFeedbackRasterizationStreamSelect = false
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 1
	subgroupSize                      = 64
	subgroupSupportedStages: count = 6
	subgroupSupportedOperations: count = 8
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	conformanceVersion:
		major    = 1
		minor    = 3
		subminor = 0
		patch    = 0
	framebufferIntegerColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
VkPhysicalDeviceVulkan13Properties:
	maxInlineUniformTotalSize                                                     = 4294967295
Device Extensions: count = 133
	VK_AMD_buffer_marker                        : extension revision 1
	VK_AMD_device_coherent_memory               : extension revision 1
	VK_AMD_draw_indirect_count                  : extension revision 2
	VK_AMD_gcn_shader                           : extension revision 1
	VK_AMD_gpa_interface                        : extension revision 1
	VK_AMD_gpu_shader_half_float                : extension revision 2
	VK_AMD_gpu_shader_int16                     : extension revision 2
	VK_AMD_memory_overallocation_behavior       : extension revision 1
	VK_AMD_mixed_attachment_samples             : extension revision 1
	VK_AMD_rasterization_order                  : extension revision 1
	VK_AMD_shader_ballot                        : extension revision 1
	VK_AMD_shader_core_properties               : extension revision 2
	VK_AMD_shader_core_properties2              : extension revision 1
	VK_AMD_shader_early_and_late_fragment_tests : extension revision 1
	VK_AMD_shader_explicit_vertex_parameter     : extension revision 1
	VK_AMD_shader_fragment_mask                 : extension revision 1
	VK_AMD_shader_image_load_store_lod          : extension revision 1
	VK_AMD_shader_info                          : extension revision 1
	VK_AMD_shader_trinary_minmax                : extension revision 1
	VK_AMD_texture_gather_bias_lod              : extension revision 1
	VK_EXT_4444_formats                         : extension revision 1
	VK_EXT_calibrated_timestamps                : extension revision 2
	VK_EXT_color_write_enable                   : extension revision 1
	VK_EXT_conditional_rendering                : extension revision 2
	VK_EXT_conservative_rasterization           : extension revision 1
	VK_EXT_custom_border_color                  : extension revision 12
	VK_EXT_depth_clip_control                   : extension revision 1
	VK_EXT_depth_clip_enable                    : extension revision 1
	VK_EXT_depth_range_unrestricted             : extension revision 1
	VK_EXT_descriptor_indexing                  : extension revision 2
	VK_EXT_extended_dynamic_state               : extension revision 1
	VK_EXT_extended_dynamic_state2              : extension revision 1
	VK_EXT_external_memory_dma_buf              : extension revision 1
	VK_EXT_external_memory_host                 : extension revision 1
	VK_EXT_global_priority                      : extension revision 2
	VK_EXT_global_priority_query                : extension revision 1
	VK_EXT_hdr_metadata                         : extension revision 2
	VK_EXT_host_query_reset                     : extension revision 1
	VK_EXT_image_robustness                     : extension revision 1
	VK_EXT_image_view_min_lod                   : extension revision 1
	VK_EXT_index_type_uint8                     : extension revision 1
	VK_EXT_inline_uniform_block                 : extension revision 1
	VK_EXT_line_rasterization                   : extension revision 1
	VK_EXT_load_store_op_none                   : extension revision 1
	VK_EXT_memory_budget                        : extension revision 1
	VK_EXT_memory_priority                      : extension revision 1
	VK_EXT_non_seamless_cube_map                : extension revision 1
	VK_EXT_pageable_device_local_memory         : extension revision 1
	VK_EXT_pci_bus_info                         : extension revision 2
	VK_EXT_pipeline_creation_cache_control      : extension revision 3
	VK_EXT_pipeline_creation_feedback           : extension revision 1
	VK_EXT_primitive_topology_list_restart      : extension revision 1
	VK_EXT_private_data                         : extension revision 1
	VK_EXT_provoking_vertex                     : extension revision 1
	VK_EXT_queue_family_foreign                 : extension revision 1
	VK_EXT_robustness2                          : extension revision 1
	VK_EXT_sample_locations                     : extension revision 1
	VK_EXT_sampler_filter_minmax                : extension revision 2
	VK_EXT_scalar_block_layout                  : extension revision 1
	VK_EXT_separate_stencil_usage               : extension revision 1
	VK_EXT_shader_atomic_float                  : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation   : extension revision 1
	VK_EXT_shader_image_atomic_int64            : extension revision 1
	VK_EXT_shader_stencil_export                : extension revision 1
	VK_EXT_shader_subgroup_ballot               : extension revision 1
	VK_EXT_shader_subgroup_vote                 : extension revision 1
	VK_EXT_shader_viewport_index_layer          : extension revision 1
	VK_EXT_subgroup_size_control                : extension revision 2
	VK_EXT_texel_buffer_alignment               : extension revision 1
	VK_EXT_tooling_info                         : extension revision 1
	VK_EXT_transform_feedback                   : extension revision 1
	VK_EXT_vertex_attribute_divisor             : extension revision 3
	VK_EXT_ycbcr_image_arrays                   : extension revision 1
	VK_GOOGLE_decorate_string                   : extension revision 1
	VK_GOOGLE_hlsl_functionality1               : extension revision 1
	VK_GOOGLE_user_type                         : extension revision 1
	VK_KHR_16bit_storage                        : extension revision 1
	VK_KHR_8bit_storage                         : extension revision 1
	VK_KHR_bind_memory2                         : extension revision 1
	VK_KHR_buffer_device_address                : extension revision 1
	VK_KHR_copy_commands2                       : extension revision 1
	VK_KHR_create_renderpass2                   : extension revision 1
	VK_KHR_dedicated_allocation                 : extension revision 3
	VK_KHR_depth_stencil_resolve                : extension revision 1
	VK_KHR_descriptor_update_template           : extension revision 1
	VK_KHR_device_group                         : extension revision 4
	VK_KHR_draw_indirect_count                  : extension revision 1
	VK_KHR_driver_properties                    : extension revision 1
	VK_KHR_dynamic_rendering                    : extension revision 1
	VK_KHR_external_fence                       : extension revision 1
	VK_KHR_external_fence_fd                    : extension revision 1
	VK_KHR_external_memory                      : extension revision 1
	VK_KHR_external_memory_fd                   : extension revision 1
	VK_KHR_external_semaphore                   : extension revision 1
	VK_KHR_external_semaphore_fd                : extension revision 1
	VK_KHR_format_feature_flags2                : extension revision 2
	VK_KHR_get_memory_requirements2             : extension revision 1
	VK_KHR_global_priority                      : extension revision 1
	VK_KHR_image_format_list                    : extension revision 1
	VK_KHR_imageless_framebuffer                : extension revision 1
	VK_KHR_maintenance1                         : extension revision 2
	VK_KHR_maintenance2                         : extension revision 1
	VK_KHR_maintenance3                         : extension revision 1
	VK_KHR_maintenance4                         : extension revision 2
	VK_KHR_multiview                            : extension revision 1
	VK_KHR_pipeline_executable_properties       : extension revision 1
	VK_KHR_pipeline_library                     : extension revision 1
	VK_KHR_push_descriptor                      : extension revision 2
	VK_KHR_relaxed_block_layout                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge         : extension revision 3
	VK_KHR_sampler_ycbcr_conversion             : extension revision 14
	VK_KHR_separate_depth_stencil_layouts       : extension revision 1
	VK_KHR_shader_atomic_int64                  : extension revision 1
	VK_KHR_shader_clock                         : extension revision 1
	VK_KHR_shader_draw_parameters               : extension revision 1
	VK_KHR_shader_float16_int8                  : extension revision 1
	VK_KHR_shader_float_controls                : extension revision 4
	VK_KHR_shader_integer_dot_product           : extension revision 1
	VK_KHR_shader_non_semantic_info             : extension revision 1
	VK_KHR_shader_subgroup_extended_types       : extension revision 1
	VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
	VK_KHR_shader_terminate_invocation          : extension revision 1
	VK_KHR_spirv_1_4                            : extension revision 1
	VK_KHR_storage_buffer_storage_class         : extension revision 1
	VK_KHR_swapchain                            : extension revision 70
	VK_KHR_swapchain_mutable_format             : extension revision 1
	VK_KHR_synchronization2                     : extension revision 1
	VK_KHR_timeline_semaphore                   : extension revision 2
	VK_KHR_uniform_buffer_standard_layout       : extension revision 1
	VK_KHR_variable_pointers                    : extension revision 1
	VK_KHR_vulkan_memory_model                  : extension revision 3
	VK_KHR_workgroup_memory_explicit_layout     : extension revision 1
	VK_KHR_zero_initialize_workgroup_memory     : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 1
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = true
		VkQueueFamilyGlobalPriorityPropertiesKHR:
			priorityCount  = 4
			priorities: count = 4
				QUEUE_GLOBAL_PRIORITY_LOW_KHR
				QUEUE_GLOBAL_PRIORITY_MEDIUM_KHR
				QUEUE_GLOBAL_PRIORITY_HIGH_KHR
				QUEUE_GLOBAL_PRIORITY_REALTIME_KHR
	queueProperties[1]:
		queueCount                  = 4
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
			priorityCount  = 4
	queueProperties[2]:
		minImageTransferGranularity = (16,16,8)
		queueCount                  = 1
		queueFlags                  = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
			priorityCount  = 1
			priorities: count = 1
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 2
	memoryHeaps[0]:
		size   = 3221225472 (0xc0000000) (3.00 GiB)
		budget = 3060164096 (0xb6666600) (2.85 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags:
			None
	memoryHeaps[1]:
		size   = 2147483648 (0x80000000) (2.00 GiB)
		budget = 2040109440 (0x79999980) (1.90 GiB)
		flags: count = 2
			MEMORY_HEAP_DEVICE_LOCAL_BIT
			MEMORY_HEAP_MULTI_INSTANCE_BIT
memoryTypes: count = 8
	memoryTypes[0]:
		heapIndex     = 1
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
			IMAGE_TILING_OPTIMAL:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D16_UNORM_S8_UINT
				FORMAT_D32_SFLOAT_S8_UINT
			IMAGE_TILING_LINEAR:
				color images
	memoryTypes[1]:
		heapIndex     = 0
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[2]:
		heapIndex     = 1
		propertyFlags = 0x0007: count = 3
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[3]:
		heapIndex     = 0
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				color images
	memoryTypes[4]:
		heapIndex     = 1
		propertyFlags = 0x00c1: count = 3
			MEMORY_PROPERTY_DEVICE_COHERENT_BIT_AMD
			MEMORY_PROPERTY_DEVICE_UNCACHED_BIT_AMD
		usable for:
				None
				None
	memoryTypes[5]:
		heapIndex     = 0
		propertyFlags = 0x00c6: count = 4
		usable for:
				None
				None
	memoryTypes[6]:
		heapIndex     = 1
		propertyFlags = 0x00c7: count = 5
		usable for:
				None
				None
	memoryTypes[7]:
		heapIndex     = 0
		propertyFlags = 0x00ce: count = 5
		usable for:
				None
				None
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = false
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = false
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = true
	sparseResidencyImage2D                  = true
	sparseResidencyImage3D                  = true
	sparseResidency2Samples                 = false
	sparseResidency4Samples                 = false
	sparseResidency8Samples                 = false
	sparseResidency16Samples                = false
	sparseResidencyAliased                  = true
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = false
	storageInputOutput16               = true
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = false
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
	colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
	depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceDynamicRenderingFeatures:
	dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
	extendedDynamicState2                   = true
	extendedDynamicState2LogicOp            = false
	extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceGlobalPriorityQueryFeaturesKHR:
	globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeatures:
	robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
	minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeatures:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = false
	bresenhamLines           = true
	smoothLines              = false
	stippledRectangularLines = false
	stippledBresenhamLines   = true
	stippledSmoothLines      = false
VkPhysicalDeviceMaintenance4Features:
	maintenance4 = true
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
	memoryPriority = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = false
	multiviewTessellationShader = true
VkPhysicalDeviceNonSeamlessCubeMapFeaturesEXT:
	nonSeamlessCubeMap = true
VkPhysicalDevicePageableDeviceLocalMemoryFeaturesEXT:
	pageableDeviceLocalMemory = true
VkPhysicalDevicePipelineCreationCacheControlFeatures:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
	primitiveTopologyListRestart      = true
	primitiveTopologyPatchListRestart = false
VkPhysicalDevicePrivateDataFeatures:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
	provokingVertexLast                       = true
	transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = false
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = false
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = false
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = false
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = false
	sparseImageFloat32Atomics    = true
	sparseImageFloat32AtomicAdd  = false
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeatures:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = true
VkPhysicalDeviceShaderIntegerDotProductFeatures:
	shaderIntegerDotProduct = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
	shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeatures:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeatures:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceSynchronization2Features:
	synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTextureCompressionASTCHDRFeatures:
	textureCompressionASTC_HDR = false
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = false
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkan13Features:
	privateData                                        = true
	shaderZeroInitializeWorkgroupMemory                = true
	maintenance4                                       = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
	workgroupMemoryExplicitLayout                  = true
	workgroupMemoryExplicitLayoutScalarBlockLayout = true
	workgroupMemoryExplicitLayout8BitAccess        = true
	workgroupMemoryExplicitLayout16BitAccess       = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeatures:
I am using an AMD Ryzen 3200G with Radeon Vega. Please help, thank you.
"As with other 3rd party repositories - the repository is unsupported.
The repo is applicable for all Manjaro branches - BUT - and this is important - the pacman-mirrors tool does not support branch switching for this repo.
You are responsible for maintaining your system configuration
Goto https://nonfree.eu → follow instructions and run a full system update."
I ran paman -Syu and rebooted, I still get the same error also I am using the liqourix kernel.
:question:
This is the kernel I am using, it shows considerable performance improvements.
Solved the issue, before I only had an AMD/radeon driver installation I also had an nvidia driver installed which wine was trying to load but I had uninstalled, fixed after resetting the driver info.
