As per the title, if I install any version of kernel 6.4 or 6.5rc I get extreme graphics corruption both on the desktop and the vt. Kernels 6.3 and 6.1 do not cause this problem. The effect is difficult to describe but looks like the all text/graphics are scrolling sideways at very high speed making using either the desktop or vt impossible, I have to do a hard shut down and boot to an older kernel to post this. Anyone got any ideas?
Kernel: 6.3.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=0713b6ed-c007-4f53-8278-053a200e92d2 rw udev.log_priority=3
pcie_aspm=off
Desktop: Xfce v: 4.19.1 tk: Gtk v: 3.24.37 info: xfce4-panel, cairo-dock
wm: xfwm v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: PC Specialist product: N7x0WU v: N/A serial: N/A
Chassis: No Enclosure type: 10 serial: N/A
Mobo: CLEVO model: N7x0WU serial: N/A UEFI: American Megatrends v: 7.13
date: 01/07/2019
ID-1: BAT0 charge: 40.4 Wh (100.0%) condition: 40.4/43.8 Wh (92.2%)
volts: 16.4 min: 14.6 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
status: discharging
System RAM: total: 16 GiB available: 15.51 GiB used: 2.46 GiB (15.9%)
igpu: 64 MiB
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CM4X8GF2400C16S4 serial: N/A
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
Info: model: Intel Core i7-8550U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1837 high: 2000 min/max: 400/4000 base/boost: 1700/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 2000 2: 700 3: 2000 4: 2000 5: 2000 6: 2000
7: 2000 8: 2000 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony USB2.0 Camera driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b59e
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9")
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary,left model: Dell U2412M
serial: <filter> built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 pos: right model: BOE Display 0x0729 built: 2017
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.3.13-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl,pavucontrol
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4:5
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u1u4 state: down mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5
chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 942.67 GiB used: 309.04 GiB (32.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 005C temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 59d 11h cycles: 1,843
read-units: 37,425,165 [19.1 TB] written-units: 26,006,172 [13.3 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD My Passport 0740 drive model: WD5000BMVW-11AMCS4 family: Elements
/ My Passport (USB) size: 465.73 GiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
drive serial: <filter> fw-rev: 1007 drive-rev: 02.01A01 temp: 42 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 33d 19h cycles: 6786
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 53.71 GiB size: 52.69 GiB (98.11%) used: 18.67 GiB (35.4%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: manjaro
uuid: 0713b6ed-c007-4f53-8278-053a200e92d2
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 4319-8E39
ID-3: /home raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
used: 78.69 GiB (55.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:3 label: home uuid: 22b28fc3-cb64-4c67-80ba-bcb0f9c884d0
ID-4: /media/freecom raw-size: 465.73 GiB size: 458.23 GiB (98.39%)
used: 147.22 GiB (32.1%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: freecom uuid: cbb1536c-e84e-46f8-8587-cb6e73380ffb
ID-5: /mnt/artix raw-size: 25.39 GiB size: 24.82 GiB (97.77%)
used: 10.57 GiB (42.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:4 label: artix uuid: e8341079-e43e-4833-8e33-1fdb26eb5932
ID-6: /mnt/mx raw-size: 32.96 GiB size: 32.14 GiB (97.53%)
used: 9.36 GiB (29.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:7 label: mx uuid: 03f1d1ea-2384-4d20-ac4f-f2948302733a
ID-7: /mnt/timeshift raw-size: 117.19 GiB size: 114.79 GiB (97.95%)
used: 44.54 GiB (38.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:5 label: timeshift uuid: a8e334fe-b0bc-49a2-b755-8522ac8c9102
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:6 label: N/A
uuid: f175fd3c-e5a0-4ead-bb59-1b8731cdc118
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-3: 1-1.3:4 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 0424:2514 class-ID: 0900
Device-1: 1-1.3.3:6 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-1.3.4:7 info: Trust Input Device type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 50mA chip-ID: 145f:02f0 class-ID: 0301
Device-3: 1-5:3 info: Chicony USB2.0 Camera type: video driver: N/A
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b59e class-ID: 0e02 serial: <filter>
Device-4: 1-7:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-5: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Device-1: 2-1.1:4 info: Genesys Logic SD Card Reader and Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Device-2: 2-1.4:5 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Device-3: 2-3:3 info: Western Digital My Passport Essential (WDBACY)
type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
chip-ID: 1058:0740 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 48.0 C pch: 41.5 C mobo: N/A
Processes: 272 Uptime: 25m wakeups: 4 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1665
pm: pacman pkgs: 1660 libs: 405 tools: octopi,pamac,pikaur,trizen pm: flatpak
pkgs: 5 Shell: Sudo (sudo) v: 1.9.14p1 default: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.28```
It is an Intel laptop with built in Intel graphics and the problem is not unique to Manjaro, it also occurs on Artix.
