Scaling problems
Everytime I try to rescale my system, I get this problem. I want to use 1080p 60Hz while also using all of my screen. How should I fix this?
xrandr -q
~ » xrandr -q                                                        soumi@Hori
Screen 0: minimum 320 x 200, current 1280 x 720, maximum 16384 x 16384
eDP-1 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
   1366x768      60.06 +
   1280x720      60.00*   59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   640x400       59.88    59.98
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1 connected 1280x720+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     74.97 +  60.00    50.00    59.94
   1680x1050     59.88
   1400x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00*   50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
So as I was configuring my monitor display settings, this showed up. All I can see in my settings are scaling resolutions (1920 x 1080, 1280 x 720). But I don’t see anything that says 1080p 60Hz. How should I fix this?
Can you post /var/log/Xorg.0.log ?
And some system info ? - inxi -Fza
~ » sudo /var/log/Xorg.0.log                                   126 ↵ soumi@Hori
sudo: /var/log/Xorg.0.log: command not found
~ » inxi -Fza                                                    1 ↵ soumi@Hori
  Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=363676ef-6401-4c77-b58f-69e59d05639b rw quiet
  resume=UUID=74191adc-235f-4ce2-b1f3-9f9ec427fcac udev.log_priority=3
  Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 1
  Type: Laptop System: Acer product: Aspire A514-53 v: V1.16
  serial: <superuser required> Chassis: type: 10
  Mobo: IL model: Sneezy_IL v: V1.16 serial: <superuser required>
  UEFI: Insyde v: 1.16 date: 01/18/2021
  ID-1: BAT0 charge: 32.8 Wh (100.0%) condition: 32.8/53.0 Wh (61.8%)
  volts: 16.3 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
  serial: <filter> status: Full cycles: 386
  Device-1: hid-f4:73:35:09:1d:b5-battery model: Keyboard K380 serial: N/A
  charge: N/A status: Discharging
  Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
  arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6
  cache: L1: 160 KiB L2: 1024 KiB L3: 4 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 9524
  Speed: 3328 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3328 2: 3297
  3: 3360 4: 3346
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
  Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:3
  chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 337x190mm (13.3x7.5")
  s-diag: 387mm (15.2")
  Monitor-1: eDP-1 res: 1280x720 hz: 60 dpi: 105 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  Monitor-2: HDMI-1 res: 1280x720 hz: 60 dpi: 68
  size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
  OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio
  vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
  alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:34c8
  class-ID: 0401
  Device-2: C-Media USB PnP Sound Device type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:5 chip-ID: 0d8c:013a
  class-ID: 0300
  Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
  bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: veth7cc8729 state: up speed: 10000 Mbps duplex: full
  mac: <filter>
  bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0
  lmp-v: 5.2 sub-v: 2405 hci-v: 5.2 rev: 2405
  Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
  link-mode: peripheral accept
  service-classes: rendering, capturing, object transfer, audio, telephony
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
  class-ID: 0104
  Local Storage: total: 1.4 TiB used: 471.06 GiB (32.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B
  speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: G002
  temp: 67.8 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Intel model: HBRPEKNX0202AO
  size: 27.25 GiB block-size: physical: 512 B logical: 512 B
  speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: K5110440
  temp: 73.8 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
  ID-1: / raw-size: 69.85 GiB size: 68.2 GiB (97.64%)
  used: 21.91 GiB (32.1%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: /boot/efi raw-size: 489 MiB size: 488 MiB (99.80%)
  used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-3: /home raw-size: 162.98 GiB size: 160.96 GiB (98.76%)
  used: 128.88 GiB (80.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-1: swap-1 type: partition size: 14.9 GiB used: 498.5 MiB (3.3%)
  priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 80.0 C mobo: N/A
  Processes: 267 Uptime: 29m wakeups: 2 Memory: 7.45 GiB
  used: 3.46 GiB (46.5%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: 1409 pacman: 1398 lib: 383 flatpak: 11 Shell: Zsh
  v: 5.8 running-in: terminator inxi: 3.3.09
Xor.0.log is a log file.
You can access it with an editor or less /var/log/Xorg.0.log.
It was too long so I just pasted it in pastebin.
I used touch Xorg_0_log.txt; cat /var/log/Xorg.0.log > Xorg_0_log.txt so that I can copy all of them easily.
Can you post /etc/X11/xorg.conf ?
And you can directly transfer the log file to a text file without touch.
~ » /etc/X11/xorg.conf 1 ↵ soumi@Hori
zsh: no such file or directory: /etc/X11/xorg.conf
So I just need to cat it? Thanks! Didn’t know about that
Have a look here: ConfigurationHelp
If the auo config does not work for some reason, then you must setup xorg.conf manually.
