I just updated to the just released Firefox 103. The whole application appears too large on my 4K display. I did not have anything similar yet. Any ideas?
Update: the issue did not appear on my 1080p laptop.
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f8146f0a-3c43-4409-9067-22432d9f961e rw
resume=UUID=550acf7a-c1a1-4b84-a302-e803150a3b4d
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P8Z77-V LX v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2501
date: 07/21/2014
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
RAM: total: 7.71 GiB used: 2.32 GiB (30.1%)
RAM Report:
Info: model: Intel Core i5-3570 bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58)
stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1906 high: 2340 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1961 2: 1679 3: 2340
4: 1646 bogomips: 27289
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13c0 class-ID: 0300
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.7:3 chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 137 s-size: 712x400mm (28.03x15.75")
s-diag: 817mm (32.15")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 138
size: 708x399mm (27.87x15.71") diag: 813mm (32") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA 515.57
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel bus-ID: 2-1.7:3 v: kernel
chip-ID: 046d:081d bus-ID: 00:1b.0 class-ID: 0e02 chip-ID: 8086:1e20
class-ID: 0403 serial: <filter>
Device-2: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8168 v: 8.049.02-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.74 TiB used: 90.13 GiB (5.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 830 Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B1Q scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD501LJ
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 0-10 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: A-Data model: SE800
size: 953.87 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: PLEXTOR model: DVDR PX-810SA rev: 1.00
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 90.13 GiB (40.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: f8146f0a-3c43-4409-9067-22432d9f961e
used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 9433-FEB8
dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 550acf7a-c1a1-4b84-a302-e803150a3b4d
ID-1: /dev/sda1 maj-min: 8:1 size: 350 MiB fs: ntfs label: System-reserviert
uuid: 50F88E70F88E545E
ID-2: /dev/sda2 maj-min: 8:2 size: 118.41 GiB fs: ntfs label: System
uuid: B8969037968FF3E2
ID-3: /dev/sda3 maj-min: 8:3 size: 503 MiB fs: ntfs label: N/A
uuid: E67CB4097CB3D313
ID-4: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: Daten
uuid: B0984DD5984D9B2C
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.7:3 info: Logitech HD Webcam C510 type: Audio,Video
power: 500mA chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Device-2: 2-1.8:4 info: Logitech Illuminated Keyboard type: Keyboard,Mouse
power: 300mA chip-ID: 046d:c318 class-ID: 0300
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-6: 3-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-3.3:4 info: ASUSTek ProArt Calibration Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0b05:1828 class-ID: 0000
Hub-7: 3-3.4:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-2:2 info: Genesys Logic All-in-One Cardreader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0732 class-ID: 0806 serial: <filter>
Hub-9: 4-3:3 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-10: 4-3.4:5 info: Genesys Logic Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-3.4.4:6 info: Genesys Logic SDXC and microSDXC CardReader
power: 896mA chip-ID: 05e3:0743 class-ID: 0806 serial: <filter>
Device-2: 4-4:4 info: A-DATA SE800 type: Mass Storage driver: uas
interfaces: 1 rev: 3.2 speed: 5 Gb/s chip-ID: 125f:a89a class-ID: 0806
serial: <filter>
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 229 Uptime: 16m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1755 lib: 396 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
