I’m trying to install the sc-im spreadsheet program by following the instructions on this website https://awesomeopensource.com/project/andmarti1424/sc-im
and I got stuck on the step of entering the command make -C /usr/src/
where the Makefile is located and I get the following output.
make: Entering directory '/usr/src'
make: *** No rule to make target 'gram.y', needed by 'y.tab.c'. Stop.
make: Leaving directory '/usr/src'
This is my inxi
output:
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=187c9560-996e-4960-a002-173983fab623 rw quiet
cryptdevice=UUID=fc39baeb-cd3b-446f-8c89-e05f681e0800:luks-fc39baeb-cd3b-446f-8c89-e05f681e0800
root=/dev/mapper/luks-fc39baeb-cd3b-446f-8c89-e05f681e0800 apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Sony product: VPCEB36GM v: C6066ETJ serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Sony model: VAIO serial: <filter> BIOS: American Megatrends v: R1090Y8
date: 07/20/2010
ID-1: BAT0 charge: 25.9 Wh (91.8%) condition: 28.2/42.2 Wh (66.8%)
volts: N/A min: 107.9 model: Sony Corp. type: Li-ion serial: N/A
status: Charging
RAM: total: 3.51 GiB used: 1.74 GiB (49.5%)
Info: Dual Core model: Intel Core i5 M 460 bits: 64 type: MT MCP
arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7 cache:
L2: 3 MiB bogomips: 20224
Speed: 1463 MHz min/max: 1199/2534 MHz boost: enabled Core speeds (MHz):
1: 1463 2: 1318 3: 1709 4: 1611
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Sony driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-1.2:3
chip-ID: 0c45:6464 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.2.1
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Centrino Advanced-N + WiMAX 6250 [Kilmer Peak]
driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:0087
class-ID: 0280
Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
vendor: Sony driver: sky2 v: 1.30 port: b000 bus-ID: 04:00.0
chip-ID: 11ab:4381 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: luks-fc39baeb-cd3b-446f-8c89-e05f681e0800 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.51 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 931.51 GiB
Local Storage: total: 931.51 GiB used: 50.46 GiB (5.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPCX-24HWST1
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A02 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-L633C rev: SN01
dev-links: cdrom
ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 50.46 GiB (5.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-fc39baeb-cd3b-446f-8c89-e05f681e0800 label: N/A
uuid: 187c9560-996e-4960-a002-173983fab623
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.2:3 info: Microdia USB 2.0 Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:6464
class-ID: 0e02
Device-2: 1-1.5:4 info: Intel WiMAX Connection 2400m type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 8086:0186
class-ID: 0000
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Logitech Optical Wheel Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c018 class-ID: 0301
System Temperatures: cpu: 44.0 C mobo: 44.0 C
Processes: 214 Uptime: 1h 50m wakeups: 4 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1057 lib: 297
flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
How do I correct this?
