I am happy to announce the release of SbK Pantheon 22.0.0.3.
Pantheon uses a lot of the Gnome desktop . Some of the files that Gnome uses had to be changed or removed to create a working Manjaro installer. Because of this it is really not possible to install Gnome as a second desktop in the installed OS.
Conky starts slow in the live install media. It might start slow the first time the installed desktop is started, but should be fine after that.
- The 5.15.81 LTS kernel.
- The New KoraSpin-Purple2 icon theme with light and dark versions.
- The new SpinThemeDarkPurple4 matching Gtk and Kvantum themes in one package.
- The new Usplash-22.0.0.3 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 12/09/2022.
- An optional Firefox theme, SbK Dark Purple4, that matches the color scheme is available at Browser Themes just click on the image in Firefox to install it.
- Geary is the email app in this version, and likely going forward.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit Checking
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
Jim
