I am happy to announce the release of SbK Mate-Compiz 21.2.2.
- The 5.15.16 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New FlatRemixSpin-Gold3 icon theme with light and dark versions of the control icons.
- The new SpinThemeDarkGold4 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.2 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 1/28/2022.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
- A basic Conky with a color scheme to match the other themes.
Jim
