I am very pleased to announce the release of SbK Lxqt 21.1.5.
This is a sharp one. I was able to spend a little more time on this release having the wallpapers picked out after the last release.
- The 5.10.70 LTS kernel.
- The New FlatRemixSpin-Purple icon theme with light and dark versions of the control icons.
- The new KvSpinDarkPurple matching Gtk and Kvantum themes in one package.
- The new Usplash-21.1.5 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The iso’s are up to date as of 10/8/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install. http://spins.tuxfamily.org/repo.html
- A basic Conky with a color theme that matches the desktop themes.
Jim
