I am happy to announce the release of SbK Cinnamon 21.2.4.
The FlatRemixSpin package was getting rather large. I split the package into FlatRemixSpinBase and FlatRemixSpin2. Then I created FlatRemixSpin3 that holds the icons for this release series and maybe future series going forward. I might move to FlatRemixSpin-(series number) or FlatRemixSpin4 next.
- The 5.15.25 LTS kernel.
- The New FlatRemixSpin-Green5 icon theme with light and dark versions of the control icons.
- The new SpinThemeDarkGreen6 matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.4 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The Green Cinnamon theme in the panel iso is new.
- The iso’s are up to date as of 3/5/2022.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install
- A basic Conly with matching color theme.
Jim
