SbK Cinnamon 21.2.0.1 release
I am happy to announce the release of SbK Cinnamon 21.2.0.1.
  1. The 5.10.84 LTS kernel.
  2. The New FlatRemixSpin-Gold2 icon theme with light and dark versions of the control icons.
  3. The new KvSpinDarkGold3 matching Gtk and Kvantum themes in one package.
  4. The new Usplash-21.2.0.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
  5. The Cinnamon Gold theme in the panel iso is new.
  6. The iso’s are up to date as of 12/16/2021.
  7. This SbK Cinnamon release is based on Manjaro 21.2.0 RC2.
  1. The latest LTS kernel.
  2. A Manjaro stable install that is also AUR compatible with a lot of packages used to build packages installed…
  3. It is multiarch by default to make running wine games and other 32bit software you may run easier.
  4. The Spins by Kilz signed repository is enabled for SbK project packages.
  5. A signed iso. For information on checking signed iso’s visit Checking
  6. Bloatware has been removed (HP printer software and others).
  7. Flat packs and snaps are not installed. The back ends are also not installed but can be installed by the user.
  8. All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. To get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
  9. Timeshift autosnap installed. It takes a snapshot before upgrading so any bad upgrades can be easily reversed.
  10. A basic Conly with matching color theme.
Jim
