Every time i try to launch Steam (Runtime) it launches LSI Steam, is that supposed to happen or is there something wrong?
I’m not sure, I noticed that the other day. The running application in the dock says it’s LSI Steam when using any Steam shortcut, but it’s actually not. I can tell because Rise / Shadow of the Tomb Raider will only launch with the runtime.
Further fiddling:
- With
linux-steam-integration
installed, launching LSI Steam, Steam (Runtime) or Steam (Native) will show as LSI Steam. - With only
steam-manjaro
&steam-native
installed, both Steam (Runtime) and Steam (Native) shows as Steam (Native).
Then i’m actually running steam-manjaro but it’s displayed as LSI due to the Steam Linux Integration? That’s quite funny if i have steam-manjaro linux-steam-integration and steam-native installed, it’s displayed as (Native) regardless of which one i launch
I don’t know why it’s happening. All the installed files appear to be in order.
Is there a way to launch Steam from terminal and check if the correct one is being launched?
Yes, you can run steam-runtime
, steam-native
or lsi-steam
. There’s no difference in behavior on my end.
How do i run it from terminal (noob question)?
I just listed the commands to run the binaries in question:
- Steam (Runtime) =
steam-runtime
- Steam (Native) =
steam-native
- LSI Steam =
lsi-steam
It seems the correct one is launching but it’s displayed as LSI or native who knows why that’s happening
