Can't edit or modify any files in my HDD
Hello there!
I’m super new to linux and manjaro. I’ve installed manjaro in an SSD after my windows kept crashing when I tried to use WSL. Long story short I switch to linux in order to explore a different ecosystem.
After installing manjaro in my SSD I noticed I couldn’t access any of my HDD files.
Tried the solution in another topic (for some reason I can’t add links)
but when executing
sudo mount /dev/sda2
I receive
mount: /dev/sdb1: can't find in /etc/fstab.
I’m using kernel v5.8.11-1
My blkid -o list
device         fs_type  label     mount point        UUID
/dev/sda1                         /boot/efi
/dev/sda2                         /
/dev/sda3                         [SWAP]
/dev/sdb1                         (not mounted)
Something that am I missing?
thanks in advance
Hello.
Those dont line up … but I assume is just a little posting mistake.
But …
What it actually seems to be is that you dont have a defined path in /etc/fstab so you need to state it in the command. Example:
sudo mount /dev/sdb1 /mnt
PS. Ah heres some docs:
https://wiki.archlinux.org/index.php/File_systems#Mount_a_file_system
It worked! Thanks for the reference doc =)
Cheers! Have fun penguining. :penguin: :slight_smile:
