I’m using my phone to access it there is an app called x-plore.
yes I do use username and password to access it
Guess your phone app only supplies SMB1 which newer samba releases have disabled.
You should add a ‘client min protocol=NT1’ to your smb.conf (global section). Also use IP addresses instead of names which probably will disappear since nmbd is a dead horse.
My samba start working again I disabled Apparmor by
sudo systemctl disable apparmor
I found solution on this thread for some user it’s working by editing apparmor in
/etc/apparmor.d/local/usr.sbin.smbd
but for me it worked by completely disabling it.
