I have a h96 pro with Khadas vim 2 installed. I know that you are not supporting but i wanted to ask. There is color mixing on my Philips brand TV. This used to happen on Android but it get fixed tçif you change the setting to rgb. Is There a way to change your system to rgb in any way. Thank you
Hello and welcome to the forum.
What do you mean by color mixing? Can you share any image for this?
Which desktop environment are you using?
Nothing that i know of unless there is some third party custom app for this on linux.
I’m out and I’ll take a picture when I go home
Wow that’s a green screen issue in an S912 device which i have seen for the first time.
I am not sure what could be the issue though, you can try few option.
- Remove and connect hdmi cable while the board is on or power on the board without the hdmi cable connected and connect it after few minutes of powering it on.
- If you’re booting from sd card then rename u-boot.sd to u-boot.ext file in boot partition this can even kill the installation as this is a green fix for s922 boards. Make sure you backup all the important files you have on the installation.
If the above options doesn’t work then idk what could be the issue.
Good luck.
Thanks for your answer, the manjara emmc is downloaded and the problem may be caused by the television.
I wish you good work.
