Ryzen 2600 / MSi B450M Gaming Plus Monitoring/Sensors and Fans
Hello Peeps,
I was just wondering if there's a way to get Ryzen voltages and system fan monitoring and voltage monitoring enabled, im using the Freon sensors extensions / gnome.
Tempuratures work, i can see tcl temps and all that, i just cant get system fans and system voltages
I have tried the it87 method, which im not sure if that works these days, installing the module of AUR and modprobing it with no luck, it just says no such device.
Motherboard: MSi B450M Gaming Plus
CPU: Ryzen 2600
Currently, no.
Hello Team,
Basically i am trying to get better sensor readings for my Ryzen 2600, im using the MSi B450M Gaming Plus motherboard.
I did some research and found that all AMD Boards either use nct6775 or it87 appearently, so i installed the it87 dkms git package and the nct git package and none seem to work
What i find interesting, is that their is a program called CPU-X, similar to cpu-z, which reads everything perfectly fine, my processor, speeds, motherboard, bios version, all of it accept the RAM Manufacturer and fan speeds on my system fans.
So Something must be able to read the motherboard sensors.
i rebooted, tried sensors-detect and got no results besides temperature for K10.
https://aur.archlinux.org/packages/it87-dkms-git/
https://aur.archlinux.org/packages/nct6775-dkms-git/
I tried to modprobe both and it says fatal error its not in /lib/modules.
I am not sure if they are running or if theirs a fault.
Heres the output of sensors detect, in-case it helps
# sensors-detect revision $Revision$
# System: Micro-Star International Co., Ltd. MS-7B87 [1.0]
# Board: Micro-Star International Co., Ltd. B450M GAMING PLUS (MS-7B87)
# Kernel: 5.1.8-1-MANJARO x86_64
# Processor: AMD Ryzen 5 2600 Six-Core Processor (23/8/2)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           No
AMD Family 16h thermal sensors...                           No
AMD Family 17h thermal sensors...                           Success!
    (driver `k10temp')
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Intel digital thermal sensor...                             No
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Probing for Super-I/O at 0x4e/0x4f
Trying family `VIA/Winbond/Nuvoton/Fintek'...               Yes
Found unknown chip with ID 0xd451
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no): y
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Using driver `i2c-piix4' for device 0000:00:14.0: AMD KERNCZ SMBus
Next adapter: NVIDIA GPU I2C adapter (i2c-0)
Do you want to scan it? (YES/no/selectively): n
Next adapter: SMBus PIIX4 adapter port 0 at 0b00 (i2c-1)
Do you want to scan it? (YES/no/selectively): y
Client found at address 0x4a
Probing for `National Semiconductor LM75'...                No
Probing for `National Semiconductor LM75A'...               No
Probing for `Dallas Semiconductor DS75'...                  No
Probing for `National Semiconductor LM77'...                No
Probing for `Analog Devices ADT7410/ADT7420'...             No
Probing for `Analog Devices ADT7411'...                     No
Probing for `Maxim MAX6642'...                              No
Probing for `Texas Instruments TMP435'...                   No
Probing for `National Semiconductor LM73'...                No
Probing for `National Semiconductor LM92'...                No
Probing for `National Semiconductor LM76'...                No
Probing for `Maxim MAX6633/MAX6634/MAX6635'...              No
Probing for `NXP/Philips SA56004'...                        No
Client found at address 0x50
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 Yes
    (confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'...                                No
Client found at address 0x51
Next adapter: SMBus PIIX4 adapter port 2 at 0b00 (i2c-2)
Next adapter: SMBus PIIX4 adapter port 3 at 0b00 (i2c-3)
Next adapter: SMBus PIIX4 adapter port 4 at 0b00 (i2c-4)
Next adapter: NVIDIA i2c adapter 1 at 1f:00.0 (i2c-5)
Do you want to scan it? (yes/NO/selectively): y
Next adapter: NVIDIA i2c adapter 3 at 1f:00.0 (i2c-6)
Next adapter: NVIDIA i2c adapter 4 at 1f:00.0 (i2c-7)
Next adapter: NVIDIA i2c adapter 5 at 1f:00.0 (i2c-8)
Client found at address 0x4b
Probing for `Analog Devices ADT7481'...                     No
Next adapter: NVIDIA i2c adapter 6 at 1f:00.0 (i2c-9)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `k10temp' (autoloaded):
  * Chip `AMD Family 17h thermal sensors' (confidence: 9)
No modules to load, skipping modules configuration.
Unloading cpuid... OK
Do this:
sudo modprobe nct6775
Shouldn't need DKMS, the module is already in the kernel sources.
sensors-detect didn't originally find my NCT6793 SIO (Super I/O) . Took some time, but finally discovered the nct6775 module.
thanks for the response
the modprobe command did nothing ( im assuming that it actually worked ) for nct6775
[nankura@nankura-pc ~]$ sudo modprobe nct6775
i ran another sensor-detect but still yields no results, i guess my board might be it87, i read it87 is in the kernel now to but modprobe doesn't work for that.
Or i'm still missing some sort of configuration or setup for nct6775
If it didn't give you an error, it loaded...check with:
lsmod | grep -i nct
If it gives a result (provide output), then run:
sensors
Note: NOT sensors-detect
Provide output.
[nankura@nankura-pc ~]$ lsmod | grep -i nct
pinctrl_amd 32768 0
[nankura@nankura-pc ~]$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
Tdie: +24.6°C (high = +70.0°C)
Tctl: +24.6°C
i find this interesting though from detect
According to the it87 github ( this may apply for nct as well ) the address 0xd451 means something.
The nct6775 module didn't load. :thinking:
do the modprobe again, and immediately the lsmod...nothing in between.
Provide output.
apologies, i was at work and just got home
[sudo] password for nankura:
nct6775                73728  0
hwmon_vid              16384  1 nct6775
pinctrl_amd            32768  0
Ok, now run just sensors; not sensors-detect.
Post output.
it all seems to work now o.o strangely, im not home right now sorry so i didnt get the output but fan speeds, voltages, temps, are all there
