I’ve got a very strange symptom here.
I run the latest stable Manjaro with two graphic cards (RX6800 and an older HD 6570).
At first after boot, everything runs fine. However, after some time (30 minutes), I notice that both the input and output lag get larger: I press a key or click the mouse and get my response later and later up to the point where the whole system is unusable.
Now here a some interesting facts:
- that happens only on the monitor that is connected to the RX6800. So when I move the active window to the other monitor that is connected to the HD6570, I get again normal responsiveness. When I move it back, it’s slow again
- mayby this observation is related to it, maybe not: the RX6800 is not recognized in the Hardware Configuration window. It is shown there as “unknown device name (ATI Technologies Inc” whereas the other graphic cards is shown correctly as “Turks PRO (HD 6570…)”.
A lspci -v shows that other parts of my system recognize the card pretty well:
13:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] (rev c3) (prog-if 00 [VGA controller])
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0e3a
Flags: bus master, fast devsel, latency 0, IRQ 164, IOMMU group 35
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at fc300000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at fc400000 [disabled] [size=128K]
Capabilities:
Kernel driver in use: amdgpu
Kernel modules: amdgpu
- the RX6800 is connected to a UHD/4K display
That sounds like a very weird issue, I hope somebody can help.
Yes, will do. Here it is:
Kernel: 5.12.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=bb267d09-c391-4a6d-9e56-9cce8aa5bc1d ro quiet apparmor=1
security=apparmor udev.log_priority=3 amd_iommu=on iommu=pt hugepages=2048
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming X serial: N/A
UEFI: American Megatrends v: P4.00 date: 01/19/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
status: Discharging
RAM: total: 62.73 GiB used: 7.37 GiB (11.8%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: 32 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: N/A part-no: CMK64GX4M2E3200C16 serial: N/A
Device-2: DIMM 1 size: No Module Installed
Device-3: DIMM 0 size: 32 GiB speed: 3200 MT/s type: DDR4
Device-4: DIMM 1 size: No Module Installed
Info: 12-Core model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3 family: 19 (25) model-id: 21 (33) stepping: N/A
microcode: A201009 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB bogomips: 177650
Speed: 3596 MHz min/max: 2200/3700 MHz base/boost: 3700/4950 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 3596 2: 3600 3: 2837
4: 2889 5: 3599 6: 3036 7: 2877 8: 2877 9: 2232 10: 3477 11: 3605 12: 2805
13: 2861 14: 2534 15: 2889 16: 2825 17: 2902 18: 2536 19: 2879 20: 2878
21: 3407 22: 2201 23: 2193 24: 2607
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Turks PRO [Radeon HD 6570/7570/8550] vendor: Hewlett-Packard
driver: radeon v: kernel bus-ID: 10:00.0 chip-ID: 1002:6759 class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited driver: vfio-pci v: 0.2 alternate: amdgpu
bus-ID: 11:00.0 chip-ID: 1002:67df class-ID: 0300
Device-3: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel bus-ID: 14:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 6038x2520 s-dpi: 96 s-size: 1593x665mm (62.7x26.2")
s-diag: 1726mm (68")
Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: DP-1-3 res: 3840x2160 hz: 60 dpi: 110
size: 885x498mm (34.8x19.6") diag: 1015mm (40")
Monitor-3: HDMI-1-1 res: 2560x1440 hz: 60 dpi: 123
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.12.0-1-MANJARO LLVM 11.1.0)
v: 3.3 Mesa 20.3.4 compat-v: 3.1 direct render: Yes
Device-1: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 10:00.1
chip-ID: 1002:aa90 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: vfio-pci v: 0.2 alternate: snd_hda_intel
bus-ID: 11:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: AMD driver: snd_hda_intel v: kernel bus-ID: 14:00.1
chip-ID: 1002:ab28 class-ID: 0403
Device-4: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 16:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.12.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Solarflare SFC9020 10G Ethernet driver: sfc v: kernel port: c100
bus-ID: 04:00.0 chip-ID: 1924:0803 class-ID: 0200
IF: enp4s0f0np0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-2: Solarflare SFC9020 10G Ethernet driver: sfc v: kernel port: c000
bus-ID: 04:00.1 chip-ID: 1924:0803 class-ID: 0200
IF: enp4s0f1np1 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: c000
bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-4: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: b000 bus-ID: 09:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Device-5: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel port: b000 bus-ID: 0b:00.0 chip-ID: 14e4:43ba
class-ID: 0280
IF: wlp11s0 state: down mac: <filter>
Device-6: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: a000 bus-ID: 0c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp12s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB
driver: btusb,hid-generic,usbhid bus-ID: 1-2.1.2:5 chip-ID: 05ac:8290
class-ID: fe01
Device-2: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Message: No LVM data was found.
Local Storage: total: 9.21 TiB used: 1.28 TiB (13.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: RKT30Q.1 temp: 31 Celsius C
scheme: GPT
SMART: yes health: PASSED on: 83d 7h cycles: 585
read-units: 23,096,308 [11.8 TB] written-units: 9,802,795 [5.01 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000DM004-2CX188
family: BarraCuda 3.5 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter>
rev: 0001 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 363d 4h cycles: 9407
read: 89.39 TiB written: 6.8 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: ISSS332-128GTP
size: 119.24 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 5J temp: 27 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 22d 20h cycles: 1039
read: 28.3 MiB written: 74.3 MiB
Optical-1: /dev/sr0 vendor: ASUS model: BW-16D1HT rev: 1.01 dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 118.95 GiB size: 116.58 GiB (98.01%)
used: 67.95 GiB (58.3%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: bb267d09-c391-4a6d-9e56-9cce8aa5bc1d
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: D979-60EE
ID-3: /run/media/kana/Spiele raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 1.21 TiB (16.7%) fs: ntfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: Spiele uuid: 9AD07E52D07E349B
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 1.82 TiB fs: apfs label: N/A
uuid: 2c16193f-74e9-425f-878f-2d82d77e90f5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 1-2.1:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.1.2:5 info: Apple Bluetooth Host Controller
type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid
interfaces: 6 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8290 class-ID: fe01
Hub-4: 1-2.2:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 1-2.2.4:6 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Device-1: 1-2.2.4.2:7 info: Genesys Logic Logilink CR0012 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 05e3:0745 class-ID: 0806 serial: <filter>
Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 2-1:2 info: VIA Labs Hub ports: 4 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 2109:0811 class-ID: 0900
Hub-8: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-9: 3-4:3 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:0811 class-ID: 0900
Hub-10: 3-4.1:5 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
Hub-11: 3-4.2:6 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
Hub-12: 3-4.3:7 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
Hub-13: 3-4.4:8 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
Device-1: 3-4.4.6:9 info: Valve Index Controller type: HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 28de:2300 class-ID: 0300 serial: <filter>
Device-2: 3-6:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-14: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-15: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-16: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
Hub-17: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-18: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
System Temperatures: cpu: 47.4 C mobo: N/A
GPU: device: amdgpu temp: 58.0 C mem: 62.0 C fan: 561 watts: 31.00
device: radeon temp: 39.5 C
Power: 12v: N/A 5v: N/A 3.3v: 3.25 vbat: N/A
Processes: 486 Uptime: 10m wakeups: 7 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1607 lib: 462
flatpak: 0 Shell: Bash (su) v: 5.1.0 running-in: yakuake inxi: 3.3.03
And some more bugs that just occured: when I just tried with kernel 5.12 and three displays (1 at the HD6570, 2 and 3 at the RX6800; that is what the above inxi shows), I’m getting screen corruption:
There are “blind” windows, they seem to be there, but they aren’t, so I can “draw” in blue with my mouse over them. See screenshot ScreenCorruption|666x500
And despite the screen adjustment saying that there are three distinct monitors (no copy), screen 2 and 3 are mirrored.
When I run the RX 6800 by its own, it just works fine. I also believe that is the case with the HD6570, that I would need to verify. So it could be the combination of the two drivers amdgpu and radeon that fails.
Edit: as for the xorg question, how do I check that? My KSysGuard doesn’t show any CPU percentage information, it’s empty. Does this answer the question?
I’ve got new information: the lag occurs even when only amdgpu drivers are used.
Next question: nobody seems to be able to comment here. I think the behaviour is clearly a severe bug. Where can I file a bug report? There are so many components in Linux that I have no idea where to go (Manjaro Forum? Arch Linux Forum? KDE forum? Kernel driver Forum?)
If it’s AMD related:
If it’s a KDE issue, then KDE Forums and/or KDE Bug Tracker.
I’d recommend you to try a different DE to see if you still have that issue in other DEs, so that you know if it’s a DE issue or a driver issue or both, before you report the issue.
So I looked up, DE means Desktop Environment. I’m not sure what to do. I am able to switch between an xorg and a wayland session, but I guess you rather mean I should enable Gnome or XKDE, is that right? I think I read somewhere that this kind of switch would be rather difficult and dangerous. I would try it anyway if it helps.
Maybe you can give me a conrete recommendation what to try next?
Did you try switching to a wayland session? What happens if you do?
Download the XFCE and/or GNOME editions of Manjaro, see if the issue is still there in the LiveISO. The best way to do it is to install one or both of these in a separate partition, update, and see if it still has the issue.
When reporting a bug to a bug tracker, it’s typically best to try as many thing as you can before reporting the bug, so that it isn’t just so broad. In this case, trying to decipher if this is a DE-related issue or not.
