When I enter “rustc --version” I get following
cmd_run.go:1046: WARNING: cannot create user data directory: cannot create “/home/#user#/snap/rustup/common”: mkdir /home/#user#/snap/rustup/common: permission denied
cannot create user data directory: /home/#user#/snap/rustup/1026: Not a directory
When I enter “sudo rustc --version” I get “rustc 1.66.1 (90743e729 2023-01-10)”
What to do that sudo is not neede here any longer?
I would probably remove all toolchains from rustup first, then uninstall all rust related packages from snap, and then install the rust package from the repository (and maybe rustup if you need that - from the repository).
