Running mkinitcpio gives me this
How can i fix this
sudo mkinitcpio -p linux
/usr/bin/mkinitcpio: line 271: /etc/mkinitcpio.d/linux.preset: No such file or directory
==> ERROR: Failed to load preset: `/etc/mkinitcpio.d/linux.preset’
You need to specify the preset file for your kernel version, for example (for kernel 4.9):
sudo mkinitcpio -p linux49
Or you can just use sudo mkinitcpio -P and it will build for all installed kernels.
Thank you. i didn’t realize Arch had upgraded it. is this a new thing for straight Arch also
I think Manjaro handles kernels a little different from Arch. For instance, there’s no linux package (like in Arch), but packages for specific kernels, such as linux49. So usage of mkinitcpio may be a little different.
like mentioned , sudo mkinitcpio -P does it for all kernels
This is not Arch at all. This is Manjaro. Arch is not Manjaro. Manjaro is not Arch.
Makes a nice little mantra, if you look at it right. :smiley:
#resist
Thanks for explaining guys :slight_smile:
It’s the little differences between Arch & Manjaro that throw me from time-to-time as well. I have each on separate machines, and can get quite frustrated with myself when I mistakenly issue the wrong command in the wrong environment. :wink: :wink: :wink:
#regards
Please do not reply to a 2 year old thread that has already been answered.
Also this is not the Arch forum. There is no linux package in Manjaro.
