I have a few posts on this subject. I want to add another one after several installs and trials and errors.
I have a 30GB flash drive that I have installed manjaro xfce on.
I will list inxi system info following this post.
The first thing I do on this system is change the screen resolution to 1920x1080 so I can read it.
The second thing I do is change the mouse touchpad to click to tap
My first issue here is it seems the system files on default install are set on read only. For example if I go to change the /etc/fstab file and go to save it, it wants me to do a save as and says the file is read only. I was expecting a prompt for the users password to allow me to save the file.
So it seems my install is not working correctly.
This is my current issue I would like to resolve.
I haven’t updated anything yet and install is a 21.2.4 I think.
I will provide any info if need to solve this.
Here is my inxi - Fazyr
[demo@fixit ~]$ inxi -Fazyr
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=dc8d1d83-fdab-4807-a085-b7b27efcf4ef rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.26 date: 07/09/2021
ID-1: BAT0 charge: 52.9 Wh (78.7%) condition: 67.2/67.2 Wh (100.0%)
volts: 12.2 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: N/A cycles: 171
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 3b:00.0
chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: eDP-1 model: AU Optronics built: 2017 res: 1920x1200 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 960.81 GiB used: 9.33 GiB (1.0%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SMI (STMicroelectronics)
model: USB size: 29.3 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1100 scheme: GPT
ID-1: / raw-size: 29 GiB size: 28.38 GiB (97.85%) used: 9.33 GiB (32.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 48.0 C pch: 45.0 C mobo: N/A
Packages: pacman: 1070 lib: 314 flatpak: 0
1: https://osmirror.org/manjaro/stable/$repo/$arch
2: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
3: https://mirror.23m.com/manjaro/stable/$repo/$arch
Processes: 236 Uptime: 39m wakeups: 2585 Memory: 15.27 GiB
used: 2.02 GiB (13.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.13
