I’m a Manjaro noob with a Pinephone, and would like some help installing AnBox on my device, which is running Manjaro ARM w/ Phosh. Could someone please supply the terminal/command line instructions for me (and others) to follow? Thanks in advance.
Hello,
To install it:
sudo pacman -S anbox anbox-image-aarch64
Or you can do it via Add/Remove Software
Then you enable the service with:
sudo systemctl start anbox-container-manager
If no bugs came about, all should be up and running.
Alternatively you can make use of waydroid
as seems to be a bit more coherent, even tho is still in early stages of development.
sudo pacman -S waydroid waydroid-image
- then add this line
binder.devices="anbox-binder,anbox-hwbinder,anbox-vndbinder,binder,hwbinder,vndbinder"
to the /boot/extlinux/extlinux.conf file after rootwait
or if you have /boot/boot.txt then add it in that file
- run
/boot/mkscr
if you had edited /boot/boot.txt - reboot your phone
- start waydroid using
sudo waydroid-start
- for stopping it use
sudo waydroid-stop
- maybe you will also have to run
pip install pyclip
- and then
pkexec setup-waydroid
Not quite sure as i did not test it in a whyle.
More on https://docs.waydro.id/
Thanks @bogdancovaciu … I’m giving AnBox a shot and extra thanks for providing the WayDroid alternative option. I’ll let you know how things pan out.
UPDATE: Anbox appeared to install properly, with no error messages returned after activating the service via “systemctl” as you directed. That said, after reviewing the AnBox website, it looks like this program may not be able to help me, as there’s an app I need to obtain via the Google Play store. I could write to its developers and request something directly… would an .apk file be the right thing to request?
I am not a developer, but as far as I know you should be with some exception able to get all apps from F-Droid website.
