Running 32 bit software on aarch64
#1
I decided to give the newest Manjaro ARM a try on my RPi3, and was (positively) surprised to see the current download is compiled for aarch64.
Does this mean I can install and use 32-bit software, for example, vivaldi-rpi? Just like I can run stuff compiled in 32-bit on Manjaro x64?
#2
No, try to use vivaldi-arm64 https://aur.archlinux.org/packages/vivaldi-arm64/ since don’t exist the equivalent of the multilib repository for aarch64/arm64
#3
I don’t think so. I haven’t tried it.
But you can give it a shot and see if it would work.
Ideally, you want to run software, compiled for the same architecture as the kernel. And on the rpi3 images, that is aarch64.
#4
Thanks! For some reason I didn’t see it when searching for it using octopi, even though I have AUR switched on in its settings.
#5
Octopi can only seach through AUR, if you have an AUR helper installed, like yay or trizen.
