Few days ago on my laptop with Manjaro I updated system, and after reboot my Wi-Fi module is not available. After short digging I found out that my Wi-Fi module has no drivers:
inxi -Fxxxz
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A pcie: speed: Unknown lanes: 63
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8852 class-ID: 0280
So I’ve tried to reinstall this driver (rtw89) with AUR and later through this git, by both of this methods end up with same error:
==> dkms install --no-depmod rtw89/r154.fe43530 -k 5.13.19-2-MANJARO
Error! Bad return status for module build on kernel: 5.13.19-2-MANJARO (x86_64)
Consult /var/lib/dkms/rtw89/r154.fe43530/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtw89/r154.fe43530 -k 5.13.19-2-MANJARO' exited 10
The log file with information:
DKMS make.log for rtw89-r154.fe43530 for kernel 5.13.19-2-MANJARO (x86_64)
Ср 02 мар 2022 14:00:18 +04
make: вход в каталог «/usr/lib/modules/5.13.19-2-MANJARO/build»
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/core.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/debug.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/mac80211.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/mac.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/phy.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/fw.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/rtw8852a.o
CC [M] /var/lib/dkms/rtw89/r154.fe43530/build/rtw8852a_table.o
cc1: ошибка: incompatible gcc/plugin versions
cc1: ошибка: failed to initialize plugin ./scripts/gcc-plugins/structleak_plugin.so
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/debug.o] Ошибка 1
make[1]: *** Ожидание завершения заданий…
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/core.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/mac80211.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/mac.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/phy.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/fw.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/rtw8852a.o] Ошибка 1
make[1]: *** [scripts/Makefile.build:273: /var/lib/dkms/rtw89/r154.fe43530/build/rtw8852a_table.o] Ошибка 1
make: *** [Makefile:1867: /var/lib/dkms/rtw89/r154.fe43530/build] Ошибка 2
make: выход из каталога «/usr/lib/modules/5.13.19-2-MANJARO/build»
It looks like there is something wrong with gcc (its version is 11.2.0
now) or/and it’s plugin structleak_plugin.so
… And here I lost. It looks like there were some problems with this plugin before (I can’t post links), but it was year ago…
