Hi everyone!
So as the title says WIFI doesn’t work. I did the following instructions but it didn’t work for me:
sudo pacman -Syyu
sudo pacman -S dkms linux59-headers
(59 since my kernel version output of uname -r
is 5.9.16-1-MANJARO)
pamac build rtl8821ce-dkms-git
I tried many things and none worked, when I do lspci
it shows my network adapter so I doubt its a hardware problem since it worked with Windows (the OS i had hours ago).
Result of journalctl -b | grep 8821ce
Mar 06 17:11:30 manjaro kernel: rtw_8821ce 0000:02:00.0: Firmware version 24.8.0, H2C version 12
Mar 06 17:11:30 manjaro kernel: 8821ce: loading out-of-tree module taints kernel.
Mar 06 17:11:30 manjaro kernel: 8821ce: module verification failed: signature and/or required key missing - tainting kernel
Mar 06 17:11:30 manjaro kernel: rtw_8821ce 0000:02:00.0 wlp2s0: renamed from wlan0
Mar 06 17:11:30 manjaro NetworkManager[633]: [1615047090.3556] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.5/0000:02:00.0/ieee80211/phy0/rfkill2) (driver rtw_8821ce)
Mar 06 17:11:31 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif b0:fc:36:51:68:25 on port 0
Mar 06 17:11:31 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif b0:fc:36:51:68:25 on port 0
Mar 06 17:11:31 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif 3e:5a:f3:8e:bd:ad on port 0
Mar 06 17:18:21 manjaro kernel: rtw_8821ce 0000:02:00.0: stop vif 3e:5a:f3:8e:bd:ad on port 0
Mar 06 17:18:22 manjaro kernel: rtw_8821ce 0000:02:00.0: start vif 9a:51:e5:00:af:fe on port 0
Thanks!
