Rpi4 GPIO?
I tried to run a python script and this is what I am getting...
$ python calib_fan.py
File "calib_fan.py", line 4, in <module>
import RPi.GPIO as GPIO
File "/usr/lib/python3.7/site-packages/RPi/GPIO/__init__.py", line 23, in <module> from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
Am I missing something?
I am running Manjaro ARM with XFCE on RPi4
Where did you get the python script?
Does it support anything other than Raspbian?
This is where I got the script...
Did you install the RPi,GPIO python library in your environment?
Yes, I did. Version is 0.6.5-2
Okay. I don't know then. Maybe it checks for something only raspbian has.
I don't use GPIO's, so I don't know. :slight_smile:
Also, you sure it supports the Raspberry Pi 4?
According to this the error could be because the script detects a wrong chipset. The rpi4 uses a different chipset than the others.
Accorging to this
the latest version is 0.7.0..
but I am getting 0.6.5 as the latest version. Does anyone know why is that?
You uses pip install RPi.GPIO in your environment to get it?
I don't know much about how python modules work.
I installed the python-raspberry-gpio package. But now that I tried the pip install RPi.GPIO it also identifies the 0.6.5 as the latest version...
That's an AUR package and is defined as version 0.7.0 for me:
python-raspberry-gpio  0.7.0-1
Try rebuilding/reinstalling it.
Ok. I am running
sudo pacman -S python-raspberry-gpio
i get Old version 0.6.5-2
New version 0.6.5-2
Is there another command I should try?
Yeah. Pacman can't do AUR.
You should try with pamac instead:
pamac build python-raspberry-gpio
No. Same thing...
Warning: python-raspberry-gpio-0.6.5-2 is up to date -- reinstalling
Nevermind. I found the issue.
It's a package I put in the repo, totally forgot to update it. Give me a few minutes.
EDIT: Just updated the package in the repo. You should get it, next time your mirror syncs.
Ok! Thank you for your time! I'll check it, when it's available...
First post from a new user here.
I have also been recently playing around with PWM fan control on Raspi Pi 4.
Are you running your script with sudo? I found I got the same message if I ran my script as a user.
In the end I gave up using the GPIO Python module because it only does software PWM, and I found it would use 6% of a RaspiPi4 CPU just running the fan.
There is another library 'wiringpi' which will do hardware PWM, but that library does not currently work with Pi 4. (The author has updated it, but it is not available in Arch or Raspbian mirrors yet), and that library would not work with a Manjaro kernel because it checks for the Hardware and Revision lines in /proc/cpuinfo which are not present in Manjaro.
For an more elegant PWM solution there is a pwm dtoverlay available. Details are in the README in /boot/overlays and refer to this page Using-the-Raspberry-Pi-Hardware-PWM-timers
For my own solution I gave up on the idea of using PWM, because the fans were noisier with PWM than without, due to the windings buzzing at the PWM frequency. Instead I use two small 30mm fans set to turn on at different temperatures.
The git repo has not been updated in over a year....
And the main website says it's been depricated.
https://gpiozero.readthedocs.io/en/stable/installing.html
I realize this is an old post but I am posting this for people in the future.
Messing with python and the GPIO pins requires things to be run as root.
I ran into this when trying to use the GPIO pins to apply voltage to a servo to fine tune a satellite lnb skew. It involves adding a GPIO group, adding you to the group and changing the ownership / permissions of /dev/gpiomem. Giving credit to my friend majortom for finding this fix:
sudo groupadd gpio
sudo usermod -a -G gpio your_user_name
sudo chown root.gpio /dev/gpiomem
sudo chmod g+rw /dev/gpiomem
reboot
This topic was automatically closed after 90 days. New replies are no longer allowed.
