Difficulty: ★★★★★
Work In Progress
Verified Boot
Please note the distinction Verified vs. Secure
- Please respect that this topic is NOT a discussion of pro’s and con’s of Secure Boot.
- Constructive feedback - errors, typos, improvements are welcome.
- Opinions on Microsoft, the boot method or TPM has been discussed ad nauseum.
- Been there done that - time to move on .
Inspiration and credit
Accidently stumbled on this [User:ZachHilman/Installation_-Btrfs%2B_LUKS2_%2B_Secure_Boot] and decided to get my feet wet and my hands dirty trying to implement encrypted Manjaro Linux using Verified Boot.
Proof of Concept
Proof of Concept project includes all what previously has been next to possible to achieve with Manjaro LInux
- no reliance on Microsoft (unless your system requires signed optional-rom image(s)
- no boot loader - the system loads directly using a signed kernel image
- full disk encryption using luks2 with argon2id
- unified kernel image
- directly signed using a custom certificate
- signing key enrolled in the firmware
Call it a primer into creating a Manjaro Linux system using Verified Boot.
There is no bootloader involved - the system is booted using EFI and a unified kernel image.
- If you use this in production - be sure to password protect your firmware.
- When it comes to boot method and the use of sbctl the installation is unsupported by Manjaro Linux.
- Due to the use of sbctl sym-links is used to point to the kernel.
- If you install another kernel - you must manually update these sym-links.
- The sym-links is found in /boot
- The installed system is otherwise fully supported.
- Should you need help otherwise be sure to mention you installed using this topic.
The script is constantly changing - the first stable version is tagged v0.1-stable
Important reading
Be sure to read FAQ · Foxboron/sbctl Wiki · GitHub and ensure your system is not using any signed option-rom images. IF you do not acknowledge this you may brick your machine. Don’t be scared - as a safe guard you have the option of enrolling factory certificates.
Hardware tested
These systems do not implement any signed option-rom images
- Clevo N141WU
- Tuxedo InfinityBook Pro 14 Gen8
- Lenovo X13 gen4
Requirements
A Manjaro ISO and a capable system.
Technically this is a two part operation.
When the initial setup has been done the script writes out a second script and drop you into a chroot where you excute stage 2.
Important customize the script
Although the script requires some interaction it is written with the intent of automating as much of the process as possible.
The script will use the default format command as described at dm-crypt/Device encryption - ArchWiki
The script configuration is in the top most part of the script and the variable names will tell you what it is used for.
The variables contains a of packages for a bare minimalist system with network - a Proof of Concept - and you will have to finalize it to get a fully functional system - see [root tip] [How To] Do a manual Manjaro installation for an idea of to proceed.
The steps
Enter the system firmware
Enable Secure Boot
Ensure Secure Boot is in setup mode
Disable factory key enrollment
Save and reboot using a Manjaro Linux ISO
Connect to network
Switch the context to root
su
Clone the script
git clone https://codeberg.org/wonky/secure-boot-setup cd secure-boot-setup
Edit the script
Unfold the details - especially the target deviceScript configuration details
################################################# # INSTALLATION CONFIGURATION # target device # !!!! be sure to get this right or you wipe the wrong device !!!! # secure wipe target - meaning filling the device with meaningless characters # recommended first time to obscure disk content _secure_wipe="yes" _target_device="/dev/nvme0n1" # encryption phrase _crypt_phrase="86343" # seconds to wait before terminating the encryption phrase prompt _timeout=300 # hostname _hostname="manjaro" # bootloader _boot_loader_label="Manjaro Verified Boot" # ----------------------------------------------- # PARTITION CONFIGURATION VARIABLES # partition order and size _efi_part="1" _efi_size="512M" _root_part="2" _root_size="256G" _swap_part="3" _swap_size="8G" # ----------------------------------------------- # SYSTEM LOCALE CONFIGURATION VARIABLES _console_keymap="dk-latin1" _console_font="lat2-16" _console_font_map="8859-1" _system_locale="en_DK.UTF-8" _system_tz="Europe/Copenhagen" _locale_gen_primary="en_DK.UTF-8 UTF-8" _locale_gen_fallback="en_US.UTF-8 UTF-8" _systemd_services="NetworkManager systemd-timesyncd systemd-resolved" # ----------------------------------------------- # PACKAGES _build_mirror="https://mirror.easyname.at/manjaro" _base="base mc micro nano" _kernel_version="6.6" _kernel="linux66" _packages="${_kernel} ${_kernel}-headers btrfs-progs efibootmgr git gptfdisk linux-firmware networkmanager plymouth polkit sbctl sudo wget" _branch="unstable" # requires plymouth 24.x # installation mountpoint _install_mount="/install" # END CONFIGURATION # DO NOT CHANGE BELOW UNLESS YOU KNOW WHY AND HOW
Save the script and execute step 1 (one)
bash encrypt-secure-boot.sh
When part1 has finished you dumped into a chroot and you must manually execute step 2 (two)
bash step2.sh
Post setup
Due to limitations in chroot - it is not always possible to enroll the generated keys into the firmware.
To continue with this last step reboot the system and login as root - this provides an excellent opportunity to test your installation before activating Secure Boot.
When logged in as root
sbctl generate-bundles -s
sbctl enroll-keys
Install a stock Manjaro desktop
Now that you have a very, very basic bootable system, you would probably want a GUI.
Please note that not all packages, normally installed for a Manjaro root filesystem has been installed.
mapare is script created by @cscs for a completely different task but we will abuse it to create a stock Manjaro desktop (You can make the mapare script install all packages by changing the -D argument to -A however it is untested for this usecase)
git clone https://gitlab.com/cscs/mapare.git
cd mapare
bash mapare -I -D
When using the -D you will need to manually add manjaro-zsh-config to get a functional .zshrs
Copy the content of /etc/skel to the home of the user you created using the initial script
cp -R /etc/skel/.* /home/<username>
You will also need to set the keyboard to be used with the desktop - if you cannot remember your chosen layout you can get it using
localectl status
Now set the locale using the VC Keymap value
localectl set-keymap <keymap>
When completed you need to enable the SDDM service
systemctl enable sddm
Now the basic setup has been done and it is time for restart
reboot
Using TPM
If you are willing to you can use TPM and one time passwords to unlock your encrypted system.
@openminded has provided some guidance in [HowTo] Using Secure Boot and TPM2 to unlock LUKS partition on boot
