Difficulty: ★★☆☆☆
Description
The scripts partitions and formats any USB device using exFAT filesystem. To avoid accidental format of non removable devices a couple of safeguards exist.
The script will check if the supplied device is valid then it checks if the device is in fact a removable device. If any of these checks fail the script aborts.
The script will ask for user confirmation twice and default to abort on Enter
Use case
Re-purpose the USB stick if you have flashed an ISO to it.
Why? Because writing an ISO using dd
writes an ISO9660 filesystem to a small part of the USB - the rest is inaccessible.
Instructions
Create the folder ~/.local/bin
mkdir -p ~/.local/bin
Create a new file e.g. format-usb.sh
touch ~/.local/bin/format-usb.sh
Make the file executable
chmod +x ~/.local/bin/format-usb.sh
Open the file with your favorite editor e.g. kate
kate ~/.local/bin/format-usb.sh
Copy below content into the file and save it.
TIP: Use the copy to clipboard box in the upper right corner of below text box
#!/usr/bin/env bash
# format removable USB device to exfat with name 'USB STICK'
LABEL='USB STICK'
# don't run as root
if [[ $(whoami) == "root" ]] ; then
echo "Please run as user. Script will ask for root later."
exit 1
fi
#!/usr/bin/env bash
# format USB device to exfat
# ensure a device is given
if [[ -z "$1" ]]; then
echo "No device specified ..."
echo "Usage: format-usb.sh /dev/sdy"
exit
fi
# get the last part of device path
device="$(echo $1 | cut -d'/' -f3)"
echo "Checking device on => $device"
# create list of available devices
devices="$(lsblk -o NAME | egrep '^sd')"
# check if device is valid - abort if not
if ! [[ $devices =~ (^|[[:space:]])$device($|[[:space:]]) ]]; then
echo "$1 not found"
echo "Aborting"
exit 1
fi
# check if device is removable - abort if not
[[ $(echo $(lsblk -no RM "$1" | head -n 1)) = '0' ]] && \
echo "Non removable device detected!" && \
echo "Aborting" && \
exit 1
# Ask for confirmation
read -r -p "Confirm reformat of '$1' [y/N] " resp
if [[ "$resp" =~ ^([yY][eE][sS]|[yY])$ ]]; then
# Repeat confirmation question
read -r -p "Irrevocably format '$1' [y/N] " resp2
if [[ "$resp2" =~ ^([yY][eE][sS]|[yY])$ ]]; then
# will do
echo "Formatting $1 ..."
# use gdisk to create new partition table
# and a single Microsoft basic data partition type
printf 'o\ny\nn\n\n\n\n0700\nw\ny\n' | sudo gdisk "$1" > /dev/null
sudo mkexfatfs -n "${LABEL}" "$1"1 > /dev/null
# done
echo "Done"
exit
fi
echo "Formatting aborted"
else
fi
Usage
Remove your USB if attached and list devices
lsblk
Insert your USB device and list the devices
lsblk
The new device in the list is your USB device e.g. /dev/sdy - format the device using the script
Note
What this script does can probably be done in numerous ways with numerous tools.
Cross posted at root.nix.dk
The list contains validation is taken from this stackoverflow topic
Revisions
2021-01-11T05:44:00Z
- Added label to format
- Cosmetic fix -> send output to /dev/null
2020-09-02T15:54:00Z
- Fix typo in device check
