[root tip] [How To] DIY installer script base (sdboot/LUKS)
Scratching the itch
I have had the urge to scratch my scripting itch.
The purpose was to add a script to my toolbox which can be used as an absolute minimal foundation for subsequent Manjaro installs. In fact with a little modification - it will actually work with Arch too - however that was not the goal.
The script initially hardcoded everything - but with my fellow Manjaro users in mind - I refactored the script to make use of a set variables - making it easy to adapt to other keyboard layouts and locales.
Feel free to amend and use whenever and wherever you like
#!/usr/bin/env bash
#    This program is free software: you can redistribute it and/or modify
#    it under the terms of the GNU General Public License as published by
#    the Free Software Foundation, either version 3 of the License, or
#    (at your option) any later version.
#    This program is distributed in the hope that it will be useful,
#    but WITHOUT ANY WARRANTY; without even the implied warranty of
#    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#    GNU General Public License for more details.
#    You should have received a copy of the GNU General Public License
#    along with this program.  If not, see <https://www.gnu.org/licenses/>.
# Copyright (c) 2021 @linux-aarhus
# The script is designed to create an absolute minimal Manjaro base
# https://forum.manjaro.org/t/root-tip-diy-installer-script-base-sdboot-luks/88502
# The target device is cleaned and
#     repurposed to hold default LUKS encrypted installation.
# The bootloader installed is systemd-boot.
# The target device can only be booted on EFI enabled systems.
# The filesystem is f2fs targeting flash devices.
if [ "$(id -u)" != "0" ]; then
    echo "Please change to root context using su or sudo"
    echo "Usage: bash sdboot-luks-setup.sh /dev/sdX"
    echo ""
    exit
fi
# ensure a device is given
if [[ -z "$1" ]]; then
    echo "No device specified ..."
    echo ""
    exit
fi
TARGET="$1"                               # target device from first argument
KERNEL="5.10"                             # linux kernel number
KERNELPKG=$(echo linux$2 | sed 's/\.//')  # kernel package name
MIRROR='https://repos.nix.dk/manjaro/'    # build mirror
BRANCH='unstable'                         # target branch
TKEYMAP='dk'                              # target keyboard layout
TLOCALE_CONF='en_DK.UTF-8'                # target locale.conf
TLOCALE_PRIMARY='en_DK.UTF-8 UTF-8'       # target primary locale
TLOCALE_FALLBACK='en_US.UTF-8 UTF-8'      # target fallback locale
TTIMEZONE='Europe/Copenhagen'             # target timezone
THOSTNAME='manjaro'                       # target hostname
ITER_TIME="10000"                         # luks iteration time
RETRIES="3"                               # luks decryption retries
BASE_PKGS="base $KERNELPKG mkinitcpio networkmanager f2fs-tools bash-completion"
echo "==> Unmounting $TARGET"
umount -f "$TARGET"
echo "==> Preparing disk $TARGET"
sgdisk --zap-all "$TARGET"
sgdisk --mbrtogpt "$TARGET"
echo "==> Creating EFI partition"
sgdisk --new 1::+512M \
       --typecode 1:ef00 \
       --change-name 1:"EFI System" \
       "$TARGET"
echo "==> Creating root partition"
sgdisk --new 2::: \
       --typecode 2:8304 \
       --change-name 2:"Linux x86-64 root" \
       "$TARGET"
echo "==> wiping EFI partition"
wipefs -af "$TARGET"1
echo "==> wiping root partition"
wipefs -af "$TARGET"2
echo "==> formatting EFI partition"
mkfs.vfat -F32 "$TARGET"1
echo "==> ------------------------------------------"
echo "==> Setting up root LUKS container"
echo "  -> WATCHOUT FOR THE UPPERCASE CONFIRMATION"
echo "  -> If using CapsLock remember to toggle back"
cryptsetup --type luks2 \
           --hash sha512 \
           --iter-time $ITER_TIME \
           --tries $RETRIES \
            --use-urandom luksFormat \
            "$TARGET"2
echo "==> Open LUKS container"
cryptsetup open "$TARGET"2 cryptroot
echo "==> Formatting LUKS using f2fs"
mkfs.f2fs -f /dev/mapper/cryptroot
echo "==> Mounting root partition"
mount /dev/mapper/cryptroot /mnt
echo "==> Creating /boot"
mkdir /mnt/boot
echo "==> Mounting EFI partition"
mount "$TARGET"1 /mnt/boot
echo "==> Setting branch and mirror"
pacman-mirrors --api --set-branch $BRANCH --url $MIRROR
echo "==> Syncronizing pacman databases"
pacman -Syy
echo "==> installing base system with Linux kernel $2"
basestrap /mnt $BASE_PKGS
echo "==> Configure base ..."
echo "  -> Creating file: vconsole.conf"
echo KEYMAP=$TKEYMAP > /mnt/etc/vconsole.conf
echo "  -> Creating file: locale.conf"
echo LANG=$TLOCALE_CONF > /mnt/etc/locale.conf
echo "  -> Creating file: hostname"
echo manjaro > /mnt/etc/hostname
echo "  -> Creating file: hosts"
cat > /mnt/etc/hosts <<EOF
127.0.0.1 localhost
127.0.1.1 $THOSTNAME.localdomain $THOSTNAME
EOF
echo "  -> Creating symlink: localtime"
ln -sf /usr/share/zoneinfo/$TTIMEZONE /mnt/etc/localtime
echo "  -> Setting hardware clock"
manjaro-chroot /mnt hwclock --systohc
echo "  -> Enabling services"
manjaro-chroot /mnt systemctl enable NetworkManager systemd-timesyncd
echo "  -> Modifying file: locale.gen"
echo "$TLOCALE_PRIMARY" >> /mnt/etc/locale.gen
echo "$TLOCALE_FALLBACK" >> /mnt/etc/locale.gen
echo "  -> Generating locale"
manjaro-chroot /mnt locale-gen
echo "  -> Setting up mkinitcpio.conf"
sed -i '/MODULES=/c\MODULES=(f2fs)' \
       /mnt/etc/mkinitcpio.conf
sed -i '/HOOKS=/c\HOOKS=(systemd keyboard keymap sd-vconsole block sd-encrypt autodetect modconf filesystems fsck)' \
echo "  -> Generating initrd"
manjaro-chroot /mnt mkinitcpio -P
echo "  -> Installing bootloader"
bootctl --path=/mnt/boot install
echo "  -> Updating entries with device UUID"
devuuid=$(lsblk -no uuid "$TARGET"2 | head -n1)
echo "  -> Creating loader entry: manjaro.conf"
cat > /mnt/boot/loader/entries/manjaro.conf <<EOF
title   Manjaro
linux   /vmlinuz-$KERNEL-x86_64
initrd  /initramfs-$KERNEL-x86_64.img
options root=/dev/mapper/cryptroot rd.luks.name=$devuuid=cryptroot
EOF
echo "  -> Creating fallback entry: manjaro-fallback.conf"
cat > /mnt/boot/loader/entries/manjaro-fallback.conf <<EOF
title   Manjaro (fallback)
initrd  /initramfs-$KERNEL-fallback-x86_64.img
EOF
echo "  -> Setting default loader"
sed -i '/default/c\/default manjaro\*/' /mnt/boot/loader/loader.conf
echo "==> Setting target branch and mirror"
pacman-mirrors --api --prefix /mnt --set-branch $BRANCH --url $MIRROR
echo "  -> Setup your root password"
manjaro-chroot /mnt passwd
echo "==> Cleaning up"
echo "  -> Unmounting partitions"
umount -R /mnt
echo "  -> Closing LUKS container"
cryptsetup close /dev/mapper/cryptroot
sync
echo "==> Done! Minimal base is now installed and configured"
echo "==> TODO: Install GUI - configure swap ..."
echo ""
Source: Manjaro base using sdboot and luks | root.nix.dk
notes and extras
