Difficulty: ★☆☆☆☆
Add Thunar custom actions
Thunar allows the user to create their own actions based on the content of the file manager window.
Here is some of mine which is used with the Openbox Community Edition
What we will cover
- Write ISO to USB
- Open a terminal using the current folder
- Launching Thunar as administrator
- Edit configuration as admin using GUI
How?
All custom actions are defined using the Configure custom actions… dialog in Thunar. It is found in the Edit menu.
All examples will follow the pattern
- Navigate the Edit menu
- Click Configure custom actions…
- Click + to add an action
- Configure the action
- Save the action
Only the first example will detail the action of opening the Configure custom action dialog
Write ISO to USB
For ISO writing I have a preference for Mint stick. I am thinking it is because it does 2 two things and does it well. There is several benefits using Mint stick
- Mint stick only allows USB devices
- USB device formatting
- USB image writing
Install mintstick
package
sudo pacman -Syu mintstick
Open Thunar and navigate to Edit → Configure custom actions…
Click the + add an action
- Name: Write to USB
- Description: Write selected ISO to USB
- Command: mintstick -m iso -i %f
Select a nice icon by clicking the icon e.g.
- from the Device icons dropdown locate the media-flash-memory-stick icon.
Click the Appearance Conditions tab
- File patter: *.iso
- Select only the Other Files option
- Shortcut: Click and press e.g. F7
Click OK and close the window.
Test it by navigating to a folder containing an ISO. Then right click the ISO and select the new Write to USB option.
Close Mint stick and test selected shortcut e.g. F7.
Open terminal here
Opening a terminal in a folder is probably one of the most useful features of the file manager. You can use a named terminal or you can use the exo-open
app to launch the system’s terminal defined by Preferred applications. To be able to use this you need the package exo
installed. You can check if it is installed using which exo-open
Click + in the custom actions dialog to configure a new action
- Name: Open Terminal Here
- Description: Open terminal in current folder
How do we get it to open in the folder currently open in Thunar?
At the bottom of the Basics tab is a list of parameters you can use when executing a command.
In this case we want the current folder to be the location opened in the terminal.
We look at the list and fine the %d parameter
%d directory containing the file that is passed in %f
Another parameter is referenced %f and this is exactly what we need
%f the path to the first selected file or directory
So our command will be
- Command: exo-open --launch TerminalEmulator %d
Next is shortcut
- Keyboard Shortcut: F4
And icon
- Select a suitable icon - a terminal
Now move to the Appearance Conditions tab
- File Pattern:
- Select only the Directories option
Save the action by clicking OK
Launch Thunar as root
- Name: Open Thunar as ROOT
- Description: Open Thunar as ROOT
- Command: thunar admin:%d
The admin: is a protocol which allows for tasks to be launched with administrative privileges. We are again using the %d parameter to use the current folder for root actions.
- Keyboard Shortcut: CtrlF8
And icon
- Select a suitable icon - red folder as a consequence alert
- File Pattern:
- Select Directories, Text Files and Other Files option
Edit config as root using GUI
- Name: Edit file as ROOT
- Description: Edit file as ROOT
- Command: xed admin:%f
The command should be an editor supporting the admin protocol. This is true for xed
and gedit
. We use the %f parameter to pass the full path of the selected file to the editor
- Keyboard Shortcut: None
And icon
- Select a suitable icon - something signifying the consequence of the action
- File Pattern:
- Select only the Text Files option
Recreate on other systems
Creating the actions from scratch is a tedious task - if you have many. The easy way is to copy this file to another system.
~/.config/Thunar/uca.xml
Conclusion
You have now learned how you create custom actions in Thunar. I hope you find the guide useful.
More reading
