My root is taking up 42.5 GiB, which doesn’t seem right. Running du -cha --max-depth=1 / | grep -E "M|G" yields
34M /dev
du: cannot access '/run/user/1000/doc': Permission denied
du: cannot access '/run/user/1000/gvfs': Permission denied
144G /run
14M /etc
58M /tmp
165M /boot
du: cannot access '/proc/30817/task/30849/fd/96': No such file or directory
du: cannot access '/proc/152960/task/152960/fd/4': No such file or directory
du: cannot access '/proc/152960/task/152960/fdinfo/4': No such file or directory
du: cannot access '/proc/152960/fd/3': No such file or directory
du: cannot access '/proc/152960/fdinfo/3': No such file or directory
25G /var
110G /home
17G /usr
7.2M /root
526M /opt
295G /
295G total
My home is mounted on a different partition, and for some reason timeshift mounts my home folder again in /run, so taking out 220G from the calculation yields 75G. Clearing the pacman cache yielded me a few GiB, but it’s still sitting above 30 GiB. I do some development, but this isn’t normal, is it?
That’s quite a lot for /var ─ mine only takes up 3.2 GiB with an empty pacman cache. Perhaps you should investigate what’s taking up so much space in there.
Looks like I have 4.1G of journals… can I remove some of them? The rest seem to be miscellaneous configs and applications each taking a nibble out of root.
