I am setting up a configuring rofi, but being quite clumsy when it comes to terminal commands and all that, setting up a new piece of software can be quite challenging.
Anyway, I got rofi running with the basics, and then I dived in to get a clipboard manager configured. After looking around a bit my choice fell on qlipmon
and I was in luck because it was available on AUR.
I installed it and started the service:
systemctl --user start qlipmon-server.service
I can run it with
rofi -modi qlipmon -show qlipmon
but all I get is a dissapointing:
qlipmon no clipboard history!
On https://github.com/vcalv/qlipmon it says I should have a $HOME/.config/qlipmon/server.ini
file, but I dont have that. Could that be the problem, perhaps?
Anybody knows why this is not working, please?
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=dc9d5ed1-acd3-4c02-a140-0b1e68d3271d rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: ASRock model: Z370 Pro4 serial: <filter>
UEFI-[Legacy]: American Megatrends v: P4.30 date: 10/31/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech M705 serial: <filter> charge: 5%
RAM: total: 15.56 GiB used: 4.33 GiB (27.8%)
Info: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: EA
cache: L2: 9 MiB bogomips: 33613
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:699f
class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96
OpenGL: renderer: Radeon RX550/550 Series (POLARIS12 DRM 3.40.0
5.10.61-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:aae0 class-ID: 0403
Device-3: Logitech Headset H390 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-9:3 chip-ID: 046d:0a44
class-ID: 0300
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: f000 bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Local Storage: total: 1.14 TiB used: 558.8 GiB (48.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00ZF5A0
type: N/A serial: <filter> rev: 0A80 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 228.23 GiB (98.00%)
used: 99.85 GiB (43.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: dc9d5ed1-acd3-4c02-a140-0b1e68d3271d
ID-2: /mnt/Marvels_daddy raw-size: 893.17 GiB size: 878.15 GiB (98.32%)
used: 422.87 GiB (48.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Marvels_daddy uuid: 59b08e4b-1a8f-45f2-a410-5629bc1b1b7b
ID-3: /run/timeshift/backup raw-size: 38.34 GiB size: 37.68 GiB (98.28%)
used: 36.07 GiB (95.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: Timeshift uuid: 404732aa-045c-4759-b8b0-0366e051437d
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-9:3 info: Logitech Headset H390 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 046d:0a44 class-ID: 0300
Hub-2: 1-10:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-10.2:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1519
Processes: 308 Uptime: 2h 18m wakeups: 19 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1263
pacman: 1243 lib: 360 flatpak: 11 snap: 9 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
