x86 iso
error while prarsing theme:
unexpected invalid import value, expecting end of file
content of .config/rofi/config.rasi
@import Manjaro
have to delete or use default config to fix this issue.
x86 iso
@import Manjaro
Are you sure it is
@import Manjaro
and not
@import "Manjaro"
Also, what is the content of .config/rofi/Manjaro.rasi
if it exists?
Edit: oh well, it is an escaping issue. Will fix it immediately.
copied from the source:
@import Manjaro
exist.
Thanks for fixing it.
You will have to remove the erroneously created file or add the quotation marks yourself tho.
